Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP 6210 all in one
I have had the printer about a year. It has always worked great. It is still printing but. When the print job begins and the carriage sets to begin printing, it makes a very loud grinding noise. When I open the carriage and watch what is happenig, I see a washer with teeth going around. I am not sure if this is the problem or not, because until the noise I never paid any attention. The printer has not been moved or mishandled so I don't know why it was not making a noise and now is. Also when I replaced the ink cartridges I noticed below the black ink there was a ***** of think drying ink. Perhaps the previous cartridge was faulty. Regardless I replaced the cartridge but it is still noisy.
Thanks for all your suggestions.
  • delishdi5 Aug 01, 2008
    I did all things you suggested. I cannot find anything to cause a paper jam. I cannot see anything at all. I am not sure where to turn to turn the paper spool.
    The ink thing you probably were right about. I did as you suggested and will hope for the best. Printer is printing, but I still get the loud noise. I have only had a paper jam once or twice. It has been really good about not jamming.
  • 876 Answers
Since you have had it a number of years and it would no longer be under warranty, you might want to try a few things. it sounds to me as if there is something in the printer > a scrap of paper> a some little object, etc. So I would look in the area where you would clear a paper clog and make sure it is clean. You might try turning the paper spool up until it clicks. Sometimes this will reset the printer and it will disgorge whatever is there.. On the other hand the cartridge thing is disturbing. I would try to clean that dried stuff off if possible, but very carefully with a qtip or a tiny instrument- be very careful not to bend or break any wires. Turn off you printer and BE SURE YOUR PRINTER IS UNPLUGGED WHILE YOU ARE DOING THIS. NOW TAKE OUT YOUR Other CARTRIDGEAND HAVE A GOOD LOOK AT BOTH CARTRIDGE SOCKETS. DOES EVERYTHING LOOK THE SAME? (Sorry about the caps)Nothing bent or broken in one? Now if all is okay replace your cartridges. Do they feel as though they are going in correctly? Plug your printer back in and turn it on. None of this will hurt your printer but it might help. If this doesnt work at all, It could also be that the cartridges were not put in when the carriage was in the correct position. So you could take them both out> turn off your printer> unplug it> wait a bit> then plug it back in>turn it back on and allow the empty carriage to move to where it should be when you install a new cartridge. Then try installing the cartridges again. Let me know if any of this helps.
Posted on Aug 01, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 01, 2008
    In my printer, for instance, there is a door on the back that I can open to clear a bad jam. there is a roller all the way across this area. You can getle roll it upward until it clicks and this will sometimes reset the printer. If you can find this place on yours, It might help.
Cancelled a job and it stays in queue
Cancel all the documents in the print queue, (just do it whether they are actually deleted or not), press "cancel" on button the printer and restart your system and also the printer. If possible, please leave the printer switched off for few minutes and don't forget to use the "Power" button to turn if off or on. This will help your printer to restart new print job, all the jobs on the print queue will be deleted/cleared. Good luck, Thanks for using FixYa.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
I have the HP Officejet 6210, it prints but will not scan
If you are flat bed scanning then try this....Try scanning through the top feeder instead. Mine has had this problem before and it has solved it.
Dec 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I can't cancel a document on my hp 6210, so it won't let me print. I shut down my system in the middle of printing yesterday and it won't work now. please help
Suggestion. Leave the printer OFF.
Power up the PC and when it is set to go, look at the bottom right side of the scree and see if there is a small printer icon. If there is, then double click on the icon.
This opens the print queue. With the print queue, highlight the print job that is causing the problem and then cancel it.
Don
Dec 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I have a document in the que which I can't delete
Shutdown the PC . Then just pull the power plug from the back of the printer for 30 secs.
Afterwards turn on the printer first, then the PC. It should clear out.
Sep 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
After I send to print the printer begins and picks up the paper hen all the lights begin blinking
remove all the cartridges and put it back again in the printer and than try to print , see if that resolve the issue
Aug 09, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Mar 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Wont print
    I'll have to begin with the obvious...
    Have you set the printer preferences correctly for contact sheets?
    Check all of your default printer settings in control panel>printers & faxes> your printer>right click>preferences
    If these are not correct for what you are printing you need to set up your printer for what you are printing at the time.
    (You may know all this already)
    I would also do a left click on the printer icon and cancel all documents if there are any in line.
    I would then turn off the printer, open the paper jam door and give the paper roller a gentle push upward until it clicks. close the paper Jam door.
    Unplug the printer.
    Wait about 15 minutes. plug it back in and turn it on and give it a new try ( remember to do the setup for whatever you are printing)
    Good luck. Let me know if this works!
    Aug 16, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Office jet 6210 - multifunctional
    Open the back door & clean the rollers. Hope this helps.
    Apr 01, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    HP OfficeJet 6210 All-In-One InkJet Printer Logo
    129 people viewed this question
    Seeker5211
    Seeker5211
