Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
E4 flashing and water not draining away - Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
My machine drain well...but the water doesn't want to go in...constantly flushing out...
Posted on Nov 14, 2014
  • Smeg Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Mar 14, 2011
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Are the dishwashers supposed to drain completely away as there is water sitting under the filters?
There is a check valve on the pump outlet where the drain hose connects to the machine. It may have something holding it open.
Nov 06, 2014 | Dishwashers
We have a belini dishwasher with E4 error code what shuld we do?
Hi, there is a few things that can cause the e4 code......
overdosing the machine can cause excessive foaming.adding soda crystals can also cause this (by clogging) or water pressure is to high.
turn off machine then tilt it backwards about 45 degrees (so it does not upset the water management system) and the water should drain away solving the error code.Hope this helps
Sep 22, 2012 | Office Equipment & Supplies
Unit stopped, displayed E4
the unit is not draining properly. unplug it from the current outlet, check behind there should be two places to drain the machine. unplug the two drain plugs in the back and let the water empty out. the e4 error message comes up when the unit is filling up with water.
Sep 04, 2011 | Royal Sovereign Portable Air Conditioner
Error code e4 flashes on belling dishwasher idw604 , washer is empty cant get any programs to work
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Dec 27, 2009 | Dishwashers
A E4 comes up water seems to be in bottom and there does not seem to be a drying mode...
E4 is overfill protection error . If that happens on drain, then it is a drain problem.
Try first tripping circuit breaker and dry water in the tub using a sponge.
Check the drain well and the filter.
Ensure drain hose at the back is not kinked.
Access pump hose , undo it and look for blockage.
Check the water level device. This is usually a float switch, on some model you also have a pressure switch.
Dec 02, 2009 | EuroTech Dishwashers
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
Kenwood dishwasher kdw8st2a
I had E4. Initially couldn't get it to clear.
In desperation, switched it off, turned it on it side and drained it onto the floor.
The E4 disappeared and the dishwasher is working normally.
Jan 22, 2008 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
366 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
