Question about Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive
HOW CAN I SET IT TO SATA 1.5 ? mY MOTHERBOARD COES NOT SUPPORT HDD WITH SATA 3.0 !
  • bianconatale Mar 18, 2011
    There are not jumpers to set up!!
    Problem Solver:
  • 16 Answers
It should be backwards compatable
but it might be that you have to switch a jumper. instructions for this should have come with the hardrive itself but if not check this out
http://www.pcguide.com/byop/byop_SettingHardDriveJumpers.htm
please mark as answered if this helped solve your problem so others in similar situations can find the answer easier
Posted on Mar 12, 2011
Beep from the system unit
1) Please make sure that the HDD IDE cable is plugged in properly on both ends. It is a 40 pin female cord which should be seated on IDE channel 1 on the motherboard.
2) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
3) Make sure taht the Jumper setting on the back of the HDD is set to MASTER
4) Login to bios and make see if you can find the HDD from the IDE drives menu. I am sure you will. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels. Select HDD as second boot device.
Feb 01, 2012 | Intel Pentium 3 , 450 MHz Pentium III...
Power not up
Feb 01, 2012 | Intel Gigabyte GA-8I845PE-RZ 845PE chipset...
My motherboard have a prablem meens chipset intel very hot and no eny pictuer in monitor
You need to perform a quick check of the following steps for us to understand the exact status of your SMPS(power supply) and Motherboard
1) Open the CPU and check whether the green light is glowing on the motherboard when power is given to SMPS.
2) Please make sure that the HDD IDE/SATA and power cables are plugged in properly on both ends.Use common sense to check, do not press very hard as the slots are sensitive.
3) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
4) Make sure that the Jumper setting on the back of the HDD is set to MASTER. NA for SATA.
5) Login to bios and make see if you can find the HDD from the drives menu. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels.
Now restart the PC and see what you get.
Jan 20, 2012 | ASUS P4P800-X Pentium Motherboard
How can I use a SATA HDD in a 7NF-RZ motherboard? What cables/adapters are required?
Hey there. To install SATA devices on any motherboard follow these steps:
1- Make sure your Motherboard supports SATA, a 7NF-RZ works fine.
2- Install the HDD on your case, usually you have to screw it in or if you have a newer case you can lock it in place with a latch.(The SATA slots on a case are usually above the optical drive slots).
3-If you have another HDD already installed, and you don't want the new HDD to have system files, make sure it's designation is set to Slave. To do this, remove the jumper on the HDD pins(a white plastic connector) with tweezers, and, according to your HDD specifications, move it up or down to Slave designation.
4-Use a SATA cable from your Power Supply and connect it to the HDD, then, use a SATA adaptor cable which should have come with your HDD and connect it to the HDD, then to your Motherboard SATA adaptor(these vary from motherboard to another, so use your Manual to specify where it is).
5-Boot up your computer, and enter BIOS. Usually press either F2,F5,F12 or Esc. After that go to Auto-Detect drivers. When you're done, Save & Exit.
You should have successfully installed your new HDD!
Aug 21, 2011 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
Can gx270 use SATA internal hard drive ?
1. You can refer to your device motherboard user manual to find it our if the SATA HDD is supported or not.
2. If you dont have motherboard manual, just remove the screws behind your computer and remove the cabinet side cover and look onto the motherboard inside it. If you find SATA slots, then you can use SATA HDDs in your machine.
3. If there is no SATA slots in your motherboard, you can still use a SATA HDD to your system by getting a PCI to SATA convertor card.
I Hope this is helpful to you
Thanks
Apr 27, 2010 | Dell OptiPlex GX270 PC Desktop
Gigabyte g31m-es2c motherboard can't detect my sata hdd
dude make sure if the jumper pin is set properly
as i think your MObo is sata 1 support and all new generation Hdd are sata2 support so u have to set the jumper pin. the setting are different fro different Hdd so check the producers website.
Mar 16, 2010 | Intel Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
P4VM800 SATA HDD Problem Plz Help me!!!
Your P4VM800 won't detect a SATA II (3 GB/s) drive, only a SATA I (1.5 GB/s). You basically have 2 options:
1. if you have a friend or colleague with a machine that supports SATA II, install the disk in that machine and us the manufacturer's utility to set the SATA to 1.5 GB/s (Seagate/Maxtor disks, but only these do have a jumper to do the job but SATA is in other respects jumperless). Then you can reinstall the disk in your machine.
2. Buy a host adapter card for SATA II and install it in a free slot in your machine - but may be better to put the money towards a new motherboard.
Oct 17, 2008 | Asrock 775Dual-880 Pro Motherboard
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
Ecs 945p-a install hdd sata
Choose in bios the setting about HDD. Choose Enhanced Sata compatibility. Now you can plug4 satas
Sep 23, 2008 | ECS 945P-A (V3.0) Motherboard
Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive Logo
226 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
