Question about Casio EXILIM ZOOM EX-Z850 Digital Camera
Exilim lens stuck closed
My daughter just got this camera 11/07 it's already broken. Any suggestions on how to fix this problem? It's stuck with the lens closed...Can this camera be reset? Had no problems before this...no drops or sand stuck.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
arclight1217
  • 208 Answers
SOURCE: Digital camera got dropped into
THIS SOUNDS TERMINAL, BUT YOU MIGHT TRY USING CANNED AIR LIKE YOU USE TO BLOW DUST OUT OF YOUR COMPUTER, AND SEE IF IT HELPS ANY. MOST OF THESE CAMERAS ARE MADE WITH THE IDEA THAT THEY WILL NEVER BE TAKEN APART OR OPENED FOR CLEANING ETC. SO, THAT IS THE ONE PROBLEM YOU ARE FACING. I DOUBT IF IT WOULD BE WORTH SPENDING THE MONEY TO SEND IT IN TO BE CLEANED. THAT CAN GET VERY EXPENSIVE IN A HURRY, PLUS TAKE A GOOD MONTH OR MORE FOR THE REPAIR. SORRY, I CAN'T HAVE MORE CHEERY NEWS, BUT THINGS LIKE THIS JUST AREN'T TAKEN INTO ACCORD WHEN THEY MAKE THESE CAMERAS. IF I CAN HELP MORE JUST REPLY TO:
ARCLIGHT1217
Posted on Nov 04, 2008
singh_shady
  • 45 Answers
SOURCE: ixus 70 dropped in sand, lens error & won't close
hi jasperke,
try the following:
make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
there is a guide to dismantle it with pictures: try it:
http://www.fixya.com/support/t102982-e_18_problem
good luck!
Posted on Jan 18, 2009
Healeyman
  • 1198 Answers
SOURCE: I dropped the camera in the sand. I turn it on and it says Lens error OX 04110000
You might try a can of compressed air, but I would see if the camera is still in warranty. I had good luck with my Canon, they sent me a new camera!
Posted on Apr 29, 2009
bozcro
  • 867 Answers
SOURCE: dropped polariod t1031 in sand. Lens is stuck.
to try and fix this(i have done it before) , pull it out when it is on , you have nothing to lose and manually assist it to open, try to get contamination out. replacing lense is probably not worth the cost
Posted on Jun 17, 2009
  • 8 Answers
SOURCE: I dropped my mx1063 in the sand at the beach. I
This is not a user solvable problem. One thing that should not be done is to turn on the camera when it has been dropped in dirt, sand or water. This will, in your case, grind the dirt around and parts try to move and contaminate additional parts of the camera. It's only worse if water is involved as this will likely cause shorts in electrical areas.
Take the camera to a repair shop and get their opinion on whether it is fixable and if so what they estimate the cost to be. Sometimes it's cheaper to buy a new or used camera.
Posted on Jul 22, 2009
I bought casio exilim recently. My problem is that there is lense error sign when I turned on camera. Please let me know how to fix this problem. Thanks. Nobuo Kuriyama
The following web blog will describe things you can try to fix this problem:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The problem is usually dirt, dust, lint, or sand that gets into the gears in the lens assembly, and they can also be stripped or damaged, but often they're just stuck.
If none of the suggestions work, you can take it into a camera repair shop, but get an estimate first, since it's sometimes better just to get a new one.
Good luck, and hope this helps.
Dec 21, 2010 | Casio Exilim EX-S600 Digital Camera
The lens opens then closes then partially opens
Maybe some of the lens gear is broken . change the gear or lens will be ok .
Aug 31, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
My Casio Exilim 7.2 Megapixel camera is stuck on zoom.
ur zoom lens trrip is broken 1side dont use zoom inout strip cost 50$
Jun 18, 2009 | Casio EXILIM Digital Camera
Repeated lens error after Casio already fixed it once
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Casio Exilim EX-Z750 Digital Camera
Casio exilim ex-z40 camera lens will not close and on/off button
Try blow compressed air around the lens, this might help if something stuck in the lens causing it not to retract. you can also try other suggestions from the link below. it's not for the same camera but it might help.
http://www.msbin.com/camera/canon-e18-error.php
Mar 23, 2009 | Casio Exilim EX-Z40 Digital Camera
I have a casio exilim ex-z60 and i accidentally drop with the lens was on, and now its stuck it wont going back(close) dis align the lens, what can i do?
try taking the battery out, and then putting it back in, and hit the power button a few times.
i drop my camera all the time.
make sure your battery is charged before you declare it broken.
[hahah, i did that once]
Nov 26, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Exilim lens
I had the same problem the thing my lens was stuck and i wiggled the lens around a little but and it closed and works fine now.. I hope thats all your problem is.
Sep 14, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Lens wont close!
goto www.digitalcamrepair.com for help their is a self diagnosis page.
May 28, 2008 | Casio Exilim EXZ75 Digital Camera
Lens is broken
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Oct 03, 2007 | Polaroid I533P Digital Camera
My lens is stuck inside the camera any help?
take it apart. That's what I did and my camera magically started working again. Just get a screwedriver or screwdriver like device and start unscrewing all the screws. make sure to watch how all the screws came out. have a clean work surface.
Jun 10, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EXILIM ZOOM EX-Z850 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Fred Block
Fred Block
Are you a Casio Camera Expert? Answer questions, earn points and help others
