Question about Wahl 9307
How do you put that little metal piece back n???? on the 9307 model trimmers....
    Master:
  • 713 Answers
Boottom peace goes that small goes first then the big peace goes on to of that.
Posted on Mar 12, 2011
  • Keee Reee
    Keee Reee Jul 02, 2014
    When you look at the spring, imagine it being the lower body of a robot...one side of the spring has loops (the hips) and the other has two ends (the feet). Hold the hips and put the feet inside the clippers touching the black part where the screws go. You'll notice a tiny black plastic tab inside the clippers between the screw holes. The bar across the spring (that goes across the knees of the robotish spring) cradles inside that bar. Next, place the black blade on the clippers with the plastic extensions cradled inside the spring. Next attach the silver blade.
When threading the top thread, where does it go when you get to the tension discs? There is a little metal piece. Does the thread go in front or in back of this little metal piece?
Here's a manual available for download:
http://manuals.husqvarnaviking.com/
If you go to page 7, you can enlarge the picture (usually holding CTRL and striking the + key several times), you may be able to see it better.
This video may also help since it appears similar to your model:
https://www.youtube.com/watch?v=6PIQliYQt8c
HINT: Be sure to RAISE the presser foot to the UP position before beginning to thread the upper thread. This helps the thread get seated in the tension disks.
Aug 06, 2015 | Sewing Machines
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
Cannot re-install spring
There is a small edge stick out at the base of the hollow mouth of trimmer. Put the spring in such a way that both the legs sticks out facing downwards. Once spring is installed, then slide the plastic holder (with rails) of the top blade on the spring and keep holding until you put together the bottom piece and tight it. Easy
Apr 09, 2013 | Wahl 9307
Parts for a 9307a
Feb 10, 2013 | Wahl 9307
I have a Toro 4 cycle gas trimmer that won't stay running. Starts, then sputters, then dies. I've changed the oil, drained fuel & put in new fuel.
check to make sure the air filter and the fuel screen are clean, the screen is the little white plastic piece on the end of the hose in the tank. if it is still sputtering try cleaning the bell out on the carb. it is the little metal cylinder on the bottom of the carb where it holds the fuel until it evaporates into the engine if it gets clogged the engine will not run properly.
Jun 30, 2011 | Garden
Could you please explain how I change from the nylon line trimming head to the metal cutting blade on my Echo brush cutter model SRM-22GES? Thanks for your help.
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Apr 25, 2011 | Garden
Will not turn off
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Was this helpful? Yes No 4 people thought this was helpful
Add a comment
    • davjones101
    • 1 minute ago
    Thanks ,very helpful. Let me just add a vital bit of information On removing front assembly, to remove sliding switch and access spring clip under blue button you have to release locking clip (it's like a long sprung piece of plastic) from LH side by just pushing it to the right with a fine screwdriver etc. It's concealed under another piece of plastic. I also removed inward facig lug on shaver body (under slider) as this snags the metal spring when refixed
    Reply
Oct 17, 2010 | Braun Syncro 7526 Electric Shaver
I need to rewind the spring and starter pull cord. I need to understand how all the parts fit together
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
GOOD LUCK!!
Nov 28, 2007 | Braun Syncro 7526 Electric Shaver
Wahl 9307 Logo
849 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
