I have an Olsen furnace and the problem I have is the blower motor will not turn on until I spin it by hand but when the furnace shuts down the blower will not kick back on unless I spin it by hand again.
    Guru:
  • 683 Answers
You have a bad run capicitor.
Posted on Mar 12, 2011
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
Hi i have an goodman capf036a2a furnace and when i cut on the heat the burner light but the blower motor doesnt turn its makes a humming noise and the code it reads is #33 roller blowout. do i need to...
Since the motor is humming we know it is recieving voltage, try spinning the blower wheel by hand and see if the motor starts up, if it does the capacitor needs to be replaced, if not the blower motor needs to be replaced.
Nov 28, 2012 | Heating & Cooling
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
Fi have a older furnace that operates like this. main burners will come on then the blower turns on and furnace continues to heat untill it shuts down on the high limit. there is no blockage on the cold...
Maybe there is a blockage in the air conditioning coil above the furnace? This happens when people have pets, or dont use filters. Single phase 120-240 volt motors won't run backwards if you reverse the wiring that's dc or three phase, you have to check the rotation of the wheel, the right rotation is usually marked on the blower case. Some motors will allow you to change the rotation but you have to check the wiring diagram. Also use new capacitors when they go bad the motor can run backward. God luck
Dec 20, 2011 | Honeywell L4064B2236 Fan/Limit Control...
The burner does not stay lit\r\nthe motor runs like and sounds like an airplane then shuts off in a few seconds, with the smell of something burning the thermastat is not picking up the temperature so the...
Hello, looks like the burners are not staying lit Because the furnace is going off on its high limit switch. This could be due to the blower motor being loose on the motor shaft, the blower wheel being extremely dirty, the bearing on the motor can be worn etc. Turn off power to the furnace and see if you can spin the blower wheel by hand, if not the blower wheel will need to be replaced.
Feb 09, 2011 | Heating & Cooling
Our furnace keeps shutting down soon after burner ignites inducer motor stays running wont heat until reset switch behind inducer motor is pushed
Sometimes a "Flame Sensor" gets carboned up and does not detect that the furnace has ignited, so it shuts down the fuel source. Might try cleaning that if so equipped.
Dec 05, 2010 | Goodman GPG152407041 15 SEER Packaged...
Ihave a Goodman GUS075-3 model. Turned the heat on for the first time this year. After abt 5 mins. running it started to smell like it was on fire, the breaker shut off. Now,the pilot keeps going out and...
I would suspect that your fan motor burned out. What I would suggest is wait about 1/2 hour with thermostat turned down to lowest setting where it is not trying to turn furnace on. I would then turn thermostat back up to call for heat and see what happens. Most electric motors have a thermal overload on them and if its on motor will not run until it cools back down. Even if this works I would recommend that you have motor replaced and clean blower. Hope this helps. Thanks
Nov 04, 2010 | Goodman Heating & Cooling
Furnace lights fan comes on then fan goes off furnace stays light until overtemp takes it out code flashes 4
Have some one hold the bottom door safety switch, turn furnace on wait until heating fan relay clicks, and check at terminal (Heat) & terminal (neutral or where all the white wires are located on the control board) for 115 volts to 120 volts. If voltage is present replace blower motor, if voltage drops out while running then replace control board.Turn power off to furnace, open bottom door and feel blower motor with hand, if motor is real hot replace motor. you can not oil this type of motor, it has to be replaced along with the compacitor. Good luck.
Jan 22, 2010 | Goodman Furnace Draft Inducer Blower ...
Blower motor stopped, there is a medium-loud ''electric buzz'' sound every minute or so as if trying to start the blower motor. Could be relay switch. Last week, I extracted the entire motor and fan...
you have a bad "starting capacitor" .. the capacitor is used to get the motor to start in the correct direction .. when its bad the motor doesnt know which way to turn so it just sits there buzzing until it gets hot .. that trips a thermal breaker in the motor and shuts it off ... when it cools it tries again .. dont let it do that for a long time since you could damage the moter eventually ... the starting cap is a round cyclinder probably mounted close to or on the motor (wires come from it to the motor) .. they are not expensive .. you can take the old one with you to a motor parts place so they can match it up with a new one ..
while the motor is buzzing .. if you spin the blower it will start in whatever direction you spin it ... it will run until its shut off but then wont start on its own again ... changing the starting cap will fix that ..
Aug 18, 2009 | Bryant Heating & Cooling
Goodman GMP125-5 Air Handler
REPLACE BLOWER MOTOR
if its spinning free until motor is energized motor may have bad armature or brushes.
If you energize blower and manually give fan motor a spin will it start if so replace cap.
Jan 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
218 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
