Question about Dishwashers
When on dishwasher made a funny noise and smoke was coming from it. now dishwasher is dead
    Master:
  • 414 Answers
Secure power to dishwasher at the breaker box by shutting off breaker. Some models
of Hotpoint dishwashers were recalled for electrical problems. The number for the model
and serial are inside the door on the left. You can Google for recall information.
I have run across 2 of the new dishwashers with the "square" motor pumps with bad
castings in the fan section which broke off and lodged in the motor itself.
On some models the drain solenoid will burn out and produce a nasty smell.
You can check underneath with the power off to see if the triangle shaped control
arm moves freely. You can also inspect the motor to see if it has a broken vane.
If you have aluminum wiring and the dishwasher was connected to it, often the wires
will work loose from vibration and literally burn a hole through the wire nuts themselves.
It would be located inside the connection box (Power off first before checking).
I do not recommend attaching aluminum wiring to a dishwasher for this reason.
Hope this helps locating the problem.
Posted on Mar 12, 2011
Have a lot of smoke coming from my tail pipes and histing noise when you press the gas the car drags
What color smoke white means coolant. Blue means oil. You could have loss of compression causing the drag the noise could be a air or coolant leak
May 02, 2016 | 2003 Nissan Altima
My 2005 gmc Yukon makes a ticking funny noise when I first crank it in the mornings and it lasts about 3 Sec then return to normal..and a washing machine sound is coming from under the right driver side...
Balncer pulley or the other pulleys take the belt off and start it and see if does the same. The ticking noise you should see where it comes from when you take the belt off
Mar 06, 2013 | Cars & Trucks
Shorting out when you turn the dial on front ,was making funny noise the other day too
Please post a model number. What do you mean by 'shorting out'? Was there a pop, or spark, smoke, or burning smell? What was the funny noise? A hum, a clanking, a squeal? And what area of the machine did it come from? Does the machine agitate, spin, or fill? Thanks.
Mar 11, 2011 | Washing Machines
My dishwasher is making funny noise and leaves
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jun 13, 2010 | GE Nautilus 24" Built-in Dishwasher
Smoke - My dishwasher was working yesterday when all of
This is a serious issue, you may need to contact the manufacturer about it. Check for recalls as your dishwasher is basically a fire hazard. There is a fan in the door that may caught fire or the door latch mechanism caught fire. Perhaps another part caught fire.
I also may recommend you to open a claim with the manufacturer about smoke damages or any other damage that your property may have.
Good luck.
Oct 05, 2009 | Hoover Dishwashers
Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Jun 11, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Big trouble
408-806-8766(David Bustillos-A/V repair expert from the bay area!)
Joe
Dec 18, 2007 | Progressive Computer InsigniaT 200W...
Dishwashers Logo
82 people viewed this question
Top Dishwashers Experts
