Question about Acer Aspire One Netbook 8.9" Notebook
I have acer net book. When i connect it wid my samsung 32 inch lcd. It does not display. Even when I click on display properties -> Output to -> dual display-> notbook+monitor, it does not work. I have tried all the options in dual display, but it does not work. sometimes icons from my desktop disapper, sometimes my netbook screen goes black. Pls help.
falseadress
  • 45 Answers
SOURCE: Connecting samsung monitor to my laptop
Assuming you are connecting the mointor to DVI or VGA cable. You can connect the monitor through windows. In vista, right click, personalize, display settings, You should see a greyed out monitor. Click extened the desktop onto this monitor, It should automaticaly detect itself.
In xp its similar. Right click on desktop, go to properties. You should see a screen pop up. Go to the last tab. it should be monitor. Click on teh greyed out area and click Extend the display to this monitor.
Posted on May 30, 2008
kbdesign
  • 370 Answers
SOURCE: Cannot adjust power properties on the Acer Aspire 3631WLC1
Start > Control Panel > Power Options
This work for you?
Posted on Mar 14, 2009
Geekman
  • 32281 Answers
SOURCE: acer 4520g minitor blackout
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Aug 14, 2009
  • 788 Answers
SOURCE: Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Posted on Sep 26, 2009
fmuise
  • 83 Answers
SOURCE: Hi, when I try any connection wireless. net book (acer aspire ONE
Here are a few things to try.
If you are using Windows XP Service Pack 2, refer to this Microsoft Article http://support.microsoft.com/kb/892896.
Try powering off your router for 30 seconds or so and turing it back on and try to reconnect.
Check to see if the router is giving you a IP address by running ipconfig in the command prompt. Start > Accessories > Command Prompt, and type in ipconfig. If you see an address of 169.254.x.x your router is not giving you an ip address and I would reboot your modem, computer and router at the same time.
Also could try connecting your laptop directly to your modem. If you get a connection I would contact support for the router.
Posted on Feb 24, 2010
Netbook pages to large
Try right clicking away from the icons in a blank part of the desktop in the menu left click "properties", this should take you to the familiar Windows display properties panel, click the settings tab and down and to the left you will see screen resolution my nett book works best with 1024 by 600 depending on where you are in the world it might be 1024 by 768. You shouldn't get into trouble here because normally after clicking the apply button it will show you the new screen and after 15 seconds go gack to the previous, if it is what you want click OK to keep the new setting. Good luck John
Jul 19, 2010 | Acer Aspire One PC Notebook
I just up graded my windows from vista to win 7. now my screen is not full and i hear sound out of monitor.
yes there is a prolem of video drivers.see video drivers are installed or not fo that right click on my computer then properties then hardware then device maneger and then righ click on sound controller then click on properties then update driveryou can automatically load the drivers from net but net should be connected
Jun 22, 2010 | Acer B223W 22 inch LCD Monitor
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
Hi,Have 710n when powered up shows "not optium mode" box and cant get into menu.How do you access menu? Many Thanks Bruce
In Your Desktop, Right Click -> Properties. In this Display Properties window, Click on Settings Tab.
Adjust the screen resolution to '1280 by 1024 pixels'.
Set Color Quality to 'Medium (16 bit)'
Then click on 'Advanced' Button. In Monitor Tab, Set the Screen Refresh rate to 60 Hertz. Click Apply/Ok in both the settings windows. This will Solve your Problem. Else, Try setting Color Quality to 'Highest (32 bit)'.
Oct 16, 2009 | Samsung 710N V2 17" LCD Monitor
Problem in attaching PC to LCD
Go to display properties and enable your secondary display
Sep 12, 2009 | Acer Televison & Video
Dell monitor and acer one laptop
Yes, you can connect. BUT, after that right click on the desktop and select Properties->Settings. There you will find two monitor icons. The left one is your Acer display while the right one is your new Dell Display. Select the right one and configure it. You should have the same resolution and color as the main Acer display to use it optimally.
Aug 09, 2009 | Acer Aspire One PC Notebook
Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!] Samsung LE32B650T2 32-inch Widescreen Full HD 1080p Samsung LE32B650T2 32-inch Widescreen Full HD 1080p Save On "Buy...
SPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMv
Jul 02, 2009 | Samsung LN32A550 32 in. LCD TV
Mobile getting switched off often
ME too know
Save On "Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Jul 02, 2009 | Nokia 6233 Cellular Phone
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Samsung LN32A550 32-Inch 1080p LCD HDTV
Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!]
Save On "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Dec 10, 2008 | Samsung TXJ2879 28" TV
Acer Aspire One Netbook 8.9" Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
