Question about ASUS P5VD2-MX SE Motherboard
I also got the 1 long and 2 short beeps on my mother board and ppl told me to check my graphix card well it still works also i used my onboard but it does the same beep. then i changed ram and it still gives me the beep.... i really dont know what to do now.
  • 108 Answers
Check the ram or clean it by using pencil eraser.
Posted on Mar 12, 2011
I have a P5K Deluxe asus mother board error beeps no visuals
Two beeps is usually the video card.
Do you have a spare video card to change out?
This is why people keep obsolete PCI video cards for just such tests.
Dec 05, 2015 | ASUS P5k Deluxe Socket 775 Motherboard
When I tern on my comp it is 3 beep what a problem
The Problem With RAM, If 3 short beeps( AMI bios). Video Problem Display Problem if One long beep and 2 Short beets( Award bios)
Remove the Power Connector from PC, and Open the cabinet and Locate the RAM, Remove it and put it back to same or diffent socket, or Try with New RAM.
if still no Use then it is the Display Problem, If display adapter is Onboard then motherboard needs Repair(Chip Level). try with new Graphics card. If you have any Graphics Card earliar then Try with New one. best of luck
Feb 03, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
One long beep two short beeps
I hate to say it, manish, but this board runs Award bios, and as such, one long and two short indicates a video issue, not RAM. Try reseating your video card, gymnasticsby. If you are not using an add-in card (using the onboard, in other words), disconnect your power cable from the wall, ground yourself on your computers' case, and remove the onboard battery to reset your bios to defaults. You can tweak your settings once you have a functioning display; It's rather tough to accomplish anything if you can't see what your machine is doing.
Oct 04, 2009 | DFI K8M800-MLVF Motherboard
Mother Board Display Problem
Hi, i think its a vga card or onboard card, if not make sure that you ram is tight and if u can get a dust blower and blow it, and just make sure that before u close it, u quiz in tight all the attached components on the mother board, if it refuse, then get another graphics card and try a gain.For starts u can use a very cheap Pci vga card and or AGP card. The other thing that i want u to take not of is try some friends monitor and see if it works if it fails then try the first option. However usually intel has a beep code, take not of the beep code and tell us how many times the it beep.
Hope u are help.
Cheers
Apr 27, 2009 | Intel D845GVFN Motherboard
Can we use a internal graphic card in a mother board in another m
Yes if it has the port for the graphics card it will work with the onboard graphics card just make sure then that your video output is plugged into the ATI radeon and not the onboard..or it will not work correctly. if you have anymore questions just let me know and i will answer them asap.
Apr 10, 2009 | Computers & Internet
Graphics card compatability
graphix memory is different from system memory. they type of graphix memory is not an issue.
Mar 14, 2009 | Intel D865GBF Motherboard
9600GT No Display
Have you put another power cable to the back of the Video card. There is a slot on the back of the GT for more power. Once that is plugged in beeps will stop and you should recieve signal
Feb 09, 2009 | ASUS PCI EXPRESS 2.0 GEFORCE 9600GT 512M...
Mother baord beep sounds
Which model? Are the beeps 1 long, 2 short, 1 short, or just continuously short? Continuously = RAM needs checked and/or replaced (you can download either Memtest or the Microsoft Memory Diagnostics CD's to check it) 1 long and 2 short or 1 long, 3 short = VGA card needs checked
May 29, 2008 | Intel Motherboard
M2a-vm mother board
Hi auriaskate,
Currently you are using the onboard PCI video adapter. This graphics adapter uses you're system memory to function.
If there is a problem with you're system memory the beeps can lead one to think there is a problem with the onboard video.
You can not remove the onboard adapter so there may be a problem with you're system memory. (I doupt you're memory is bad) but on the other hand it might not be fully installed correctely. Power off the PC & unplug the power cord from the PC.
Please remove you're system memory & firmly reseat it.
Plug the power cord back in. Start the PC & listen for any beeps except the 1 normal beep known as P.O.S.T = Power on self test. Any beeps after that there is a problem with a device connected to the board.
You're Asus M2A-VM uses an Award bios. Click on the link below to see what Award beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Try the memory reseat & check. Let me know if this helped.
Mike
May 03, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Disabled onboard video in bios in hopes that new video card would kick in, now how do i turn it back on so i can see again
with a second monitor and win xp, you can run both videos. just plug in card and plug in second monitor and xp will take care of the rest...you will see special messages first boot
May 28, 2007 | AOpen MX4LS (91.88Q10.001) Motherboard
ASUS P5VD2-MX SE Motherboard Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
