Question about Hotpoint Refrigerators
The fridge doesnt seem to be cold enough not sure which way to turn the dial no indication as to which way to turn. No instruction manual to refer to.
    Master:
  • 414 Answers
Make sure the freezer dial is in the middle (12 O'clock) position if it has one
If it is turned too far towards the right it will cut off all air flow to the refrigerator
compartment, the air flow from the freezer cools the lower compartment. Also make sure
the fan is running, if it has failed then the freezer will freeze up and block all air flow.
The refrigerator compartment has a cold control as well, it is normally turned toward
the right to make it colder or if it has numbers, set to 5 or above.
I recommend setting the refrigerator to 36 to 39 degrees (just above freezing). using a
thermometer (stick type set in a cup of water overnight to get an accurate reading).
It is the preferred method, and will help in this instance since the numbers aren't legible.
Hope this helps.
Posted on Mar 12, 2011
My fridge not cold enough
If you have turned the dial up as high as it can go "9" and it still is not cold enough, you will need to have some freon added. There is not to much to a fridge. Best of luck.
Dec 21, 2014 | Frigidaire FRC150FF Frost Free Fridge...
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
With the dial set to the coldest setting it doesnt get very cold it does a little but not enough to keep food from spoiling in about two days
How old is your appliance?
I don't think is safe to keep storing food in the appliance as you may get sick for food poisoning.
This may be caused by a dirty condenser. You may need to clean the back of the fridge. Be sure to remove dust and other particles that may keep the appliance working improperly. If you have the fridge installed outside - the garage, for example - put a fan to blow some air to the back of the fridge.
Aug 30, 2009 | Admiral Refrigerators
Candy Fridge - The freezer part is not cold enough, fridge ok!
A couple of things to check-
- Is the condensor cooling fan running? This will be located to push air through the external cooling coils, wherever they are located.
- Does the auto-defrost timer work? It may have failed and stayed in a position that has left the heating elements (for defrosting) turned on.
- Does it seem to be running way too long and not turning off as it once did? This could indicate either a loss of coolant (would need recharge and leak detection) or the compressor is reaching its end of life. If the latter is the problem, expect a cost of $200-$400 US.
Apr 07, 2009 | Whirlpool Gold Series GI15NDXT 15"...
Temperature adjustment
Generally the freezer temp is the REAL temp of the unit. Fans, dampers and manual control levers let some of that cold freezer air into the refer compartment to cool it. Check your owners manual for damper operations if you have one. If you have a refer temp control all that does is control a damper to let the cold freezer air into the compartment. Also make sure you don't block off any of those vents in the refer or freezer compartment or bad air circulation can occur.
Oct 05, 2006 | Candy CPCA250K Bottom Freezer Refrigerator
Refrigerators Logo
102 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
