Question about Brother MFC 420CN All-In-One InkJet Printer
My copier won't turn on is there a fuse in there and where is it located.
    Scholar:
  • 158 Answers
First make sure the plug is seated all the way in the back of the unit and firmly plugged into the wall. Also, plug a lamp into the ourtlet you are using for the copier and make sure you have voltage.
Posted on Mar 12, 2011
Where is the fuel pump relay located in this vehicle.
fuel pump fuse is fuse no35 30A
or fuse no 40 20A
fuel pump relay is incorperated in the fuse box which is located behind glovebox
Aug 23, 2016 | Cars & Trucks
Jeep grand cherokee
the fuse more than likely look inside of ur fuse box and locate the fuse and check it
Apr 25, 2013 | Cars & Trucks
Rear turn and stop lights won't work. Replaced bulbs, but still out. Can't locate a blown fuse.
On some vehicles when a light is burnt out it turns that whole section off on others the lights are individual and can burn independently. ----------------------------------------------------------------------
Multidiag Actia
Dec 04, 2012 | 2006 Ford Freestar
Where are the fuses in the harman kardon 3380 receiver, I had a lightning strike which I think knocked out my receiver thru my outdoor speakers, it will not turn on, could it be a fuse and if yes, where is...
Hello Randy,
There are two options here: first, the power button is amber but unit still won't go. In this case try a 'factory reset' as per manual. If this won't work, it seems that the processor is gone (located on the display board) so you have to bring your unit into a authorized shop for repairs. Secondly, it might be just matter of some blown fuses which are located inside the unit on the transformer board. If after replacing (if they're blown) the unit still won't work or keeps blowing the new fuses, follow the first advice, meaning you have to bring the receiver to a service. To access the fuses, you have to remove the top cover.I wish you luck
Kostiko
Sep 12, 2011 | Harman Kardon HK 3380 Receiver
Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Sep 02, 2011 | Sharp AR-M277 Digital Copier Copier
1987 vw cabriolet won't turn over, I replaced the starter and it's still not turning over my battery is fine and i don't know what to do:(
search for the IGNITION FUSE inside your fuse box, located below your dashboard. replace the fuse (make sure to use the recommended fuse rating).
Aug 06, 2011 | Volkswagen Cabriolet Cars & Trucks
My TV won't turn on - it was working fine when I turned it off and now it won't turn on...
have you checked the fuse at the back??...this just might be your problem. It is located on the power supply side of the motherboard.
Good luck and thanks for using Fixya.
G..
Jun 29, 2011 | Mitsubishi WS-48613 48" Rear Projection...
Turn signal won't work - changed bulbs and can't find were the flashers is
check the fuses located in passenger floorspace near center console. fuse cover panel should map out what fuse is what and you can test it once you find it y replacing it with a like-voltage or new fuse
May 06, 2011 | 2000 Jeep Cherokee
Where is the heater and turn signal relay located 1992 caravan
These are seperate fuses and seperate turn signal falsher which evenually go into the same wiring. See my answer to your previous question. Good luck and hope it helps.
Jan 19, 2009 | 1992 Dodge Caravan
HP VP6210 won´t turn on at all
the fuse (if it has one) is on the power supply next to where the plug plugs in. if the fuse is ok, replace the power supply.
Jul 18, 2008 | Office Equipment & Supplies
Brother MFC 420CN All-In-One InkJet Printer Logo
43 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
