Question about Acer Aspire 5610-4648 Notebook
My acer,s dvd rom dont working - Acer Aspire 5610-4648 Notebook
    Genius:
  • 1,098 Answers
Hi.
You may want to delete the upper and lower filters in your registry.In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps.
Posted on Mar 12, 2011
No everybody says delete the upper and lower case filters, i dont have any of them listed. mine says no value set. my cd rom work fine then one day stopped i got to use it four times to watch movies. i...
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps you
Aug 30, 2011 | Acer Computers & Internet
My acer aspire 5315 dvd rom doesnt work at all but somtime it do
There is a problem with the DVD ROM. Maybe it is not well fixed and causing conflict which result in making the computer slow. And maybe it is not contacting the system well again, that's why it worked and later not worked when it loose contact.
I would advice that you shut down your system, loose the DVD ROM and put the system back on without the DVD ROM after a little while when the windows must have settled, shut down the system again and fixed back the DVD ROM. Make sure it is well connected and put the system back on again. Test the DVD ROM and see if it would give the same problem. If it does, then may be you will have to replace the DVD ROM.
One a DVD ROM is bad, another one needs to be purchased, because it is usually difficult to repair DVD ROM expect in minor case.
I wish you the best.
Dec 18, 2009 | Acer Aspire 5315 Notebook
My computer says i dont have a dvd-rom but its there
hello i a have couple of questions is the dvd the one that came with the computer or did u buy it somewhere 1 if it the one that came with the acer then try here to get the drivers http://driver-pro.com/related/english/hardware-drivers/?gclid=COiGzNu-vZkCFQVhnAod41hc7w&hit=1&adurl=12034
when u get to the site scroll down slect from the list ur operating sys slect dvd and so on that should fix the problem
hope this helps you
bob
Mar 25, 2009 | Acer Aspire 3100-1405 Notebook
Acer aspire l100 dvd problem
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
thankyou
Feb 14, 2009 | Acer Aspire L100 PC Desktop
Acer Aspire 1690 DVD/CD-rom is not working
My cd/dvd rom dont work coz the drive has change to another one.I think take windows xp/vista/7/8 with an usb and inslat it. When windows finished installing try to format it because the dvd and cd rom are fixed . Thnx
Jan 16, 2009 | Acer (91.37H37.001) Internal DVD Drive
ACER 4520 CD-RW/DVD-ROM its pops up insert disc
you can try two solutions
1) go to device manager and uninstall the primary and secondary ide controller under the IDE ATA/ATAPI controllers and than restart the system and than chk it if that works out
2 ) if the first option doesnt work try to update the firmware of the drive
Sep 09, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I`m having a problem with my Acer Travel Mate 2200 laptop
in order to play a DVD you need to have a software dvd player Like WIN DVD, otherwise DVDs will not play
Jul 25, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
