Question about Brother MFC-440CN InkJet Printer
Hi, i have a Brother MFC-440CN and for some reason, on the screen it says "unable to change 50" i have no clue what this means? i was hoping you could please hel me
SOURCE: Error message 50
Confirm Success on a 440CN
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees
2) make a note of where each connector goes
3) release the Ribbon and 3 Multicore cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees.
4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.
5) Remove front panel by disconnecting ribbon and wireing on both sides.
6) Remove 6 Screws (2 on back, three at front and one middle right
7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.
8) Re-Seat Encoder Strip into guide. (The Transparent strip)
9) Re-assemble in reverse and Hey Presto.
All Cured. Hopefully!
Posted on Aug 04, 2008
SOURCE: "Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Posted on Aug 28, 2008
  • 159 Answers
SOURCE: my brother mfc 440cn read unable to clean error46
Its Ink Absorber Box is full. Inside the machine, in the back and hidden under the covers is a large plastic box with thick, felt pads packed in it. Every time the machine cleans its printheads, it squirts ink through all its nozzles, collects the mess, and pumps it into that box. After a few thousand cleaning operations, it decides the box is dangerously full of ink and throws up that Error 46.
Getting to the Ink Absorber Box (part number LP1270001) is fairly complex. I think it's time to ask a tech what he/she charges.
Posted on Aug 05, 2009
SOURCE: brother mfc 440cn Unable to change error 51
mfc-440cn unable to chang 51
Posted on Dec 02, 2009
  • 159 Answers
SOURCE: brother mfc-440cn has error unable to print 4f
The service manual says it could possibly be a bad Main Board or a power supply problem, but it always turns out to be a broken printhead. If it's under warranty (one year) get to an authorized service center and Brother will cover all the costs except your time and gas. If it's just past warranty, call Brother's customer support and beg. Sometimes they issue work orders for warranty service on machines that are past their warranty.
If it's out of warranty, I'd recommend giving up on it. The parts are expensive, it's time-consuming (expensive), and you can buy a replacement machine pretty cheaply. www.BrotherMall.com lists refurbished, more advanced machines for $90.
Posted on Sep 20, 2010
"UNABLE TO PRINT 50" appears
Error: -------- Unable to Print XX
Problem: ------------ The machine has a mechanical problem. -OR- A foreign objects such as a clip or ripped paper is in the machine.
Solution: ------------- Open the scanner cover and remove any foreign objects inside the machine. If the error message continues, do one of the following: ?? (MFC-440CN only) See Transferring your faxes or Fax Journal report on page 139 before disconnecting the machine so you will not lose any important messages. Then, disconnect the machine from the power for several minutes and then reconnect it. ??
May 22, 2011 | Brother MultiFunction Center MFC-440CN...
I have a MFC 440CN brother printer, but not work . the screen have problem 50 and I donot have manuaal
Hi
For the MFC -440CN manual please click the mention below link: --
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002183/Mini3_MfcLcdW_UkEngUsr.pdf
May 08, 2011 | Brother MFC-440CN InkJet Printer
How do i fix " unable to print 50"
Please describe your Brother Maintenance mfc295 cn problem
Jan 29, 2011 | Brother MultiFunction Center MFC-440CN...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Help
I say you throw it in the trash
Sep 23, 2008 | Brother MultiFunction Center MFC-440CN...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-440CN InkJet Printer Logo
115 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
