Question about E-Machines (T2958) PC Desktop
My computer turns on but when it does it beeps three times and the monitor says no signal, and the fan is running very fast.
    Scholar:
  • 158 Answers
3 beeps is a memory error. You need to open the memory access panel on the back of the laptop and if it is equipped with 2 modules (make sure the laptop is not powered, remove power supply and battery), using your thumbs press the metal retaining clips outward from the module and the module should pop upwards, remove one and try to turn laptop back on, if it still does the same thing put that module back in and remove the other one and try it. You might have to replace both modules. The memory might have just become unseated.
It is possible that both modules went out or even got un-seated if the laptop was suddenly dopped or jarred.
You can get new memory at 18004memory.com at a good price and usually with lifetime warranty
Posted on Mar 12, 2011
    Guru:
  • 811 Answers
This is an indication that a device is not working or is unplugged, memory modules a keyboard anything that is not working will cause a boot up beep which means a device is not functioning. Most likely it is the hard drive or a memory module go to the back of the computer and make sure that everything is plugged in,
Also since the computer is not using much power and no drain is happening as it would normally it also is an indication of a problem device if the fan is moving faster than it normally would nothing to bog it down so something is bad with your machine. I would suggest that you take it in to a local shop if you are not tech inclined to troubleshoot problems it would be a good idea to have it looked at they can tell you if the board or modules or other is the issue by testing it. Thanks for using FixYa! John
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
When i turn the power on, 3 beeps play, the fan runs and the power light comes on, but nothing else
Hearing ONE beep is normal, and a signal that the computer hardware is OK.
Hearing THREE beeps is a signal that something is wrong:
* burnt-out CPU,
* one of the fans is not spinning (clogged?) or spinning too slowly (about to seize-up),
* one of the RAM chips is defective
* the video-card is not working
If there is more than one RAM stick, remove all but one stick, and start it up, to see if it starts.
Check that the fans are spinning freely.
Dec 14, 2010 | Gateway GM5260 PC Desktop
No signal to monitor. No beeps at start up. Fans running. New video card installed (after issue began) monitor & cord are working fine (have checked both with other computer)
There might be a problem with your RAM you may check your RAM and clean it with a cotton cloth and fix it again or change your RAM and see
Or the problem can also be with your moniter
thanks
May 14, 2010 | E-Machines eMachines Desktop PC
Beeps when turned on monitor says no signal and fans do run
How many times does it beep? If it beeps seven or so times, it's your video card. If it only beeps once or twice, can't remember for sure, it's memory problem.
Dec 31, 2009 | Dell Inspiron 530s Desktop Computer
No display on monitor, 3 fast beeps when booting
3 fast beeps is a code which is telling you that there is a problem with 1 or more of the memory modules, take them out and clean the contacts with an eraser and try again, if you have more than 1 try them 1 at a time so you can work out which is the faulty 1
Nov 14, 2008 | Intel Motherboard
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
Monitor not getting signal
Check your cables.
If the cables are fine then there is something
wrong with your comuter.
Do you hear any beeping sounds?
Mar 07, 2008 | HP Compaq d530 SFF PC Desktop
E-Machines (T2958) PC Desktop Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
