Question about Lincoln Electric Lincoln Power MIG 216 Welder 230 Volt 216 Amps
I have a Lincoln 215 mig which seems to have lost much of its power. What was adequate heat at setting "D" now has to be setting "G". Does anyone know the likely cause and how much it might cost to fix?
  • 407 Answers
Hi:
Before you rush to send your machine to be fix, let's do a little troubleshooting:
Weak voltage can happen due to different problems:
1) Check your ground cable first, if your terminals are "blueish" or with signs of taking too much heat, replace them including your ground clamp.
2) Check you contact tip on the gun and tip holder these must be tight and free from spatter.
3) Check your plug at gun connection also must be tight.
If everything looks good to your eye, then check your invoice all lincoln units have 3 year warranty. Check you local welding supplier if they don't have a direct relationship with Lincoln then take your machine to your local Praxair location and they will contact Lincoln for you. Probably all you pay is the shipping.
If this was useful to you, please vote.
Posted on Mar 13, 2011
Fire power 160 heat range will not go low enough to weld thin material.
You need a smaller welder. Pick up a nice 110 unit that has at least 4 power settings. I have a lincoln 95 amp that will weld body panels on low and 1/2" on high.
Oct 17, 2013 | Firepower Welding Tools
I have a lincoln power mig 255 and every time i weld little holes appear in the welds. what could this be?
Hi:
This could be a problem of gthe gas you are using. Make sure to use mix 75/25 argon/CO2 for mild steel welding, argon 100% for aluminum and trimix helium/argon/CO2 for stainless steel.
Also check your heat (voltage) 16-22 is enough for weld of most steels less than 1/2 inch.
Aug 06, 2011 | Lincoln Magnum 100L 10' 025035
I cant seem to get consistant penetration even though i am a competant welder and have set the unit up to manafacturers spec's as well as a few degree's either way. The material is clean, well earthed, i...
try a different outlet it seems you are loosing electrical power supply and it surges in and out causing this problem.also try cleaning the inside of the wire cable every time you chance the roll of wire i use brake clean spray it inside until it pours out the other end you will be surprised what you see come out.any comments are appreciated
Nov 21, 2010 | Lincoln Mig Welder Trigger Switch Magnum...
I have a Lincoln 140 mig welder. It welds and cuts
Usually this is caused by a bad liner in the mig gun hose, or worn out guide rolls in the drive unit, or if this is not the case the speed of the wire might be set to high as this would force the wire into the weld causing the motor to heat up from resistance and shut it down on safty. Hope This Helps Don
Dec 02, 2009 | Lincoln Welding Tools
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Lincoln mig pac-100 low heat on highest setting.won't weld 20 ga.
if you are using flux core that might be why, flux core burns hotter, try using 75/25 or more argon than co2, as your gas, the gas will keep it a little cooler, keep your amps down and match the wire speed to the amps, which would be slower wire speed
Apr 15, 2009 | Lincoln Welding Tools
Heat range seems to be set very low,
you may need to switch the polarity, if you are using gas it may be set for flux core, if you are using flux core it may be set for gas. all you have to do is switch the 2 wires around. i hope this helps you
Apr 02, 2009 | Lincoln Welding Tools
My lincoln welder lost its heat penetration
It only produces 100amps. You can only weld thinner metal 3/16" comfortably. Any thicker will resuld in less/no penetration.
Mar 17, 2009 | Welding Tools
Welder probems
a mig welding unit of 100 amps is very low, you will require a small wire size, plus the contact tip, liner to suit, expect to get a maximum amperage of 70- 80 amps max, if the unit is Aluminium wound transformer then expect 6 months use, and the ampage will drop ,then its scrap, depending on the weather conditions that the unit is kept, will depend on the live of the unit.
Dec 30, 2008 | Welding Tools
Lincoln Electric Lincoln Power MIG 216 Welder  230 Volt 216 Amps Logo
261 people viewed this question
Top Lincoln Electric Welding Tools Experts
oleolson
Level 1 Expert
Daryl Gleaton
Troy
Troy
Level 1 Expert
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
