The belt has snapped and when i opened the back up the belt is nowhere to be found so i dont know the belt number to be able to get a replacement can you please help?
  • 4 more comments
  • Michael Crozier Mar 12, 2011
    what is the make and model number of the machine
  • ste_rowland2 Mar 12, 2011
    all i know is that its a haier AA 6GK
    sorry its HW-C1460TVE-U
    Haier is the make but AA 6kg means energy rating and drum size. If you open the door the model number will be on a sticker on the inside. Should start with a letter
    also is there a special way of fitting the belt ie. tension iv actualy got a belt but seems way too small the number on belt is VC021095
  • Czerney Dort Mar 12, 2011
    whats your brade and mod
    Sergeant:
    Novelist:
  • 196 Answers
Think that is the same belt used on all of haier washers. if you take it to a spares place they should be able to match it up or order online from Haier spares direct. If the motor is on the bottom then it is a matter of hooking it first around the spindle of the motor and then putting as much on as possible around the big pulley then turn the pulley slowly holding the belt on at the same time till it stretches over. Its the only way. Hope this helps
Posted on Mar 12, 2011
    iv tried soaking the belt in hot water to soften it but still cant get it to fit i will keep trying cos the missus is on my case thanks for your help if all else fails il buy her a better machine thanks again mate
My vw beetle 2.0 2002 fan belt snap i dont have sample any one can help me with a size of the belt
The snapped belt has a number mark.
How To Install Replace Engine Serpentine Belt Volkswagen ...
? 6:09
https://www.youtube.com/watch?v=urBVruIk348
Dec 31, 2011 - Uploaded by 1A Auto Parts
How To Install Replace Engine Serpentine Belt Volkswagen Beetle 1AAuto.com ... Well, the serpentine belt on my Bugbroke. And, didnt know ...
Help! Serpentine belt broke, need advice. - TDIClub Forums
https://forums.tdiclub.com/showthread.php?t=323672
Jul 11, 2011 - Basically, I think the serpentine belt blew on her, she drove about 1/8 ...TDI(s): 2005 Passat Wagon, 2004 Jetta,99.5 Golf ... BTW, last year I lost my AC belt rather abruptly. .... 2005 VW Passat GLS TDI (Chipped, BSM delete, and Manual ), 2007 VW Eos 2.0T, 2002 Mazda MPV ES, 2015 Toyota Sienna XLE. 1.6 tdi alternator belt tensioner bolt snapped
Dec 29, 2013
Serpentine Belt Tensioner (A4 ALH) Keeps breaking!!!!!!
Jul 29, 2013
Serpentine belt tensioner?
Sep 17, 2012
ALH Serp. Tensioner Damper Failure w/ pics and video
May 21, 2011
More results from forums.tdiclub.com
VWVortex.com - Broken timing belt, valves likely bent
forums.vwvortex.com > ... > Golf IV & Jetta IV
Dec 19, 2015 | Cars & Trucks
What is the fabric type belt on the front of the drum drum used for ?
that's the drum seal,that isn't a good model number,you have to replace the drum seal gasket,it holds the heat in the drum and also the clothes,if it isn't torn you can glue it back on,there should be another seal on the back of drum too.go here,put the model number in and you can look at all the parts in your dryer.
https://www.searspartsdirect.com/model/search.html?q=AWZ%203303
open the door,look around the opening where you put the clothes in and you'll see the tag with the model number
Dec 20, 2017 | Whirlpool Dryers
A technician stated my alternator belt has a slight crack...how long can I continue to drive with the crack
Nobody can tell when that alternator belt will snap, but the crack means its time to change it.
For precautionary and preventive maintenance purposes, the mechanic just advises you to change that belt before it will snap in the middle of nowhere.
If I were you I will follow the advise!
Hope that clears all the doubts!
Thank you for using Fixya!
Dec 08, 2010 | 2000 Mitsubishi Montero Sport
My dryer belt from my Whirlpool model number lgr7646dq1 snapped off and I need a diagram how the belt goes back on. I already purchased a replacment belt but do not know how it goes back on. Thanks Richard
the belt number 341241, that should be packaged with a diagram as how to wind it around the motor shaft , and the idler pulley.youll need to pull the front off the machine to gain acees to the drumm area, fom there you can drape the belt over the drum, "red side out"might be a difficult to try to hold up the drum and try to secure the belt without the use of another set of hands( the front panel that you removed holds the weight of the unit normally) afeter you get the draped belt around the ider pully "snaps into the lower cabinet so that you can pull hte tension to the right. after fully extending the pully to the right wrap the belt around motor pully and allow the idler to release and hold tension on the belt. it will only go on one way! only tricky the first time , youll get it!!!
Jan 27, 2010 | Whirlpool Dryers
Broken belt unkown model number.
if it is a newer machine whirlpool does not use belts they use couplers, if you need tech assistance live go to www.whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
My kenmore clothes dryer has stopped spinning and is just making
The pulley in question is likely a spring loaded idler pulley, used to keep tension on the belt. It likely hangs onto the dryer's frame, & is held in place by the belt. If you order a new belt from Sears, ask them for a belt path diagram, which should show the proper pulley position.
Apr 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Belt on my 19tdi has snapped and i dont know the path
if its a supertine belt the digram is shown under the hood look arround find the pitcure if just reg belt u may or may not haft to remove the other ones to get it on like say if its in the back pulley its got to bee in line with the pully on the moter u should have a slide arm on the alt with about an 1/2 eanch bolt loosen that the alt will give just enuif to get it off put back same way u take off a#1 in tn
Apr 04, 2009 | 1997 Volkswagen Passat
Samsung ML2010 laser printer paper feed roller belt
I just fought this same battle and have emerged victorious! The roller cam that the black rubber belt fits around is kind of "C" shaped in cross-section. The roller has left and right hinge-pins on one end of the "C" and snaps on the other. Looking at either side of the casing that the roller mounts in, you will see the end of the hinge-pin and a typical sqeeze clip like those often found on bigger laser printer rollers. I'm sure this was designed so that you should be able to sqeeze the left and right clips simultaneously which should release the snap end of the "C" and allow it to hinge out away from the casing. Unfortunately, it appears that the designer's good intentions were never tested. If your roller is like mine, it does not freely release by just sqeezing the clips. It was a bit awkward but while squeezing one of the clips, I used the tip of a small screw driver to pry loose the snap on that side. The trick is to hold that snap out away from it's seated position while you perform the same procedure on the other side. With both sides pryed away from their seated position you should be able to hinge the roller with black rubber belt away from it's case and remove it. In lieu of buying a replacement belt I simply rotated the existing one to expose the unused part and snapped it back in place. Voila!
Jan 26, 2009 | Samsung ML 2010 Laser Printer
My belt broke. I have a replacement. I dont know how to install the replacement belt.
There's a plastic cover over the agitator. (the part that should spin, with tough bristles)
Unscrew it. Pull out the agitator. Put the new belt over the 'spinner' (the part that's connected to the motor) and the special pafrt of the agitator. Snap the agitator back into place, making sure it's secure on both sides.
Screw back on the plastic cover.
Wallah!
Apr 25, 2008 | Vacuums
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
