Question about GRY Viore RPT50V24DHD 50" HDTV DLP TV
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
Posted on Apr 03, 2011
2 Suggested Answers
  • 8457 Answers
SOURCE: my viore tv wont stay on it keeps going off by its
Ur tv the projection lamp,inside the tv now,been on an in used about 4 or 5 hours a day,the bulb been inside tv about 1 1/2 or 2 years?The projection lamp life is over,reqiure changing?Turn tv on hear alot of clicking too?The board call the Ballast board also require changing too,this Ballast board help to ignite the projection lamp.
Posted on Jul 24, 2010
How to connect laptop to flat screen TV
You can use a VGA cable to connect to your flat screen. Then select the RGB input your tv and it should work. If your computer is new and high end enough it may have HDMI out and then I would use an HDMI cable.
Apr 01, 2013 | Viore Televison & Video
Viore tv code for ge remote 24865
Just do a code search method, rather than seeking code list to this remote. If the remote have pr-loaded code for Viore TV, this proceeding will help you. If not, you have to buy an other remote control, which have setup codes for Viore TV in its code list.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
If you succeed, there is a way to retrieve the code that was synchronized with your TV. To get more details about it, visit this site 'Electro-help'. Type in 'electronicshelponline.blogspot' to your browsers search box, and click search. It is a blogspot site, in English language. Pull up older posts there. Have all details about codes, code search, retrieving the code etc:-
Jun 23, 2012 | GE 24965 Remote Control
Old Viore Model tv will not stay on longing then 5 sec...how to reset Tv
The set has a shutdown problem, If set stays on for 5 seconds it indicates a high voltage issue, " probably the flyback" need professional to assess.
Mar 17, 2012 | Vizio Televison & Video
My viore tv wont stay on it keeps going off by its
Jul 24, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My hdmi connection wont stay on on my vior plasma 42 inch
You may have used Monster cables which can expand the plug in the TV.
Sorry, but you'll need to get a new input or use tape to hold it in.
Jun 12, 2010 | Toymax Viore 42 in. Plasma TV
Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
May 17, 2010 | Toymax Viore 42 in. Plasma TV
Cablevision remote won't work viore tv
I was able to program my viore tv by trying the code search:
1. Press the tv and sel buttons until the IO button turns red.
2. Press channel up or down until the tv turns off and the press the tv button to lock in the code.
Ps: Be pattient when searching for the code, it might take a while. HOPE THIS HELPS!!!!!!!!!!!!!!!!
Mar 09, 2009 | Toymax Viore 42 in. Plasma TV
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
Code for viore tv. 1403 does not work
Have you tried using Akai TV codes.
You could also contact Viore on 866 278 5900 or
Email Technical support. techsupport@viore.com
website www.viore.com
Jul 05, 2008 | Philips PM3S Remote Control
GRY Viore RPT50V24DHD 50" HDTV DLP TV Logo
717 people viewed this question
Top GRY Televison & Video Experts
Electro Med Services...
Are you a GRY Televison and Video Expert? Answer questions, earn points and help others
