Question about Bosch Washing Machines
Bosch WVD24520GB/01 is not progressing to the next step during washes. You have to manually select rinse and spin etc. I think the main pcb may need replacing but cannot find the part online anywhere. The numbers on the PCB are ako 7202 48-02, bsh 5560008596b. Can anyone help?
  • dnt_bug_me Mar 12, 2011
    The front display shows a count down of the wash cycle and it gets all the way to the end, where it shows 1 minute remaining and then it remains on 1 minute - it never actually completes. I've checked the filter
Did any of you find a solution for this?
Posted on Nov 26, 2011
I ALSO HAVE THE EXACT SAME PROBLEM WITH THE SAME MODEL MACHINE
Posted on Oct 30, 2011
I have developed the same problem today, has anyone found a solution yet, pls let me know.
Posted on Oct 15, 2011
  • Jason green Nov 25, 2011
    Anyone find a solution for this?
    Brigadier General:
  • 6,277 Answers
Are you sure that it's not a blocked filter causing the problems?
Just in case-
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 12, 2011
  • 5 more comments
    Thanks John, I'll check the filter then. I have removed the PCB and visually checked it and there are no signs of blown components so its possible that it isnt the circuit. I'll let you know if the filter is blocked. I'm hoping its not the board as I finally found the part on the bosch website and its 170 quid!
    About the fault, it doesnt lock up or stop, it just carrys on washing when its supposed to stop washing and move on to the next cycle. The time bar shows it should be at the end of the wash
    The front display shows a count down of the wash cycle and it gets all the way to the end, where it shows 1 minute remaining and then it remains on 1 minute - it never actually completes. I've checked the filter but its all clear. Any ideas?
    if you turn the dial manually onto rinse or drain etc it does it fine. It just doesnt complete the program end automatically.
    On the rinse cycle you hear a relay click during the last minute at the end and it completes, but at the end of the wash programs there isnt a click - so maybe one of the relays isnt working?
  • ben5152 Apr 03, 2011
    I have exactly the same problem tonight. Did you make any progress?
  • Colin Stickland
    Colin Stickland Oct 30, 2011
    if this machine is a new one with digital control mechanism then i think that only a authorised dealer can sort it out for you as like a europeon car the software is encrypted as this is to stop our retired man in france from repairing them ,Also this old cockney in eastern spain as well from repairing them .
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Why does my Bosch Classixx 1200 Washing Machine rinse if I turn switch to rinse but will not rinse when automatically.
Are you on a delicates program that has no spin or is there a no spin button that has been pressed?
Check the manual to see what programs do what. You can usually find a manual on line if you have lost yours.
Dec 13, 2014 | Bosch Washing Machines
How come my bosch WA20261AU makes loud vibrating sound and its hot inside?
Hi Yvemarie,
Based on what I searched about the machine that you have where in the beep noise can only be hear at the end of the cycle not during the cycle. And also that noise can lower down and I will provide you steps on how to do that. It seems to me also that there is some kind of an issue on your machine since you said there was steaming and smoking happening, right? If the steps I will provide below works and still doing the same thing I guess you need to have that machine serviced.
    • 1 Press and hold the "Select" button on the electric display until the acoustic signal symbol, which looks like a small speaker-phone, is illuminated on the display.
    • 2 Continue to hold down the "Select" button until the system cycles through "Continuous", "Max" and then "Off" settings.
    • 3 Release the "Select" button when "Off" is highlighted next to the acoustic symbol. The signal noise is now turned off on the washer.
Read more: How to Silence a Bosch Washing Machine ' eHow.comhttp://www.ehow.com/how_7552735_silence-bosch-washing-machine.html#ixzz1fRDAKHrO
Apr 27, 2014 | Bosch Washing Machines
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
I have a FEX831FS4 washer/dryer. The washing machine will wash and spin, but will not rinse and spin. Lid is locked.
think ur voltage is too low..usually frigidaire brand washer is 220v,..usually starting of spinning has a high ampere and it need a high volt electrical supply..try to check ur main breaker for washer only..ur lid lock will lock after 10secs when it spin fast...
Dec 02, 2012 | Washing Machines
Code F 35 i cant find my manual
christydubar --
Whirlpool Duet GHW91000 Technical Service Manual does list F35 error code. Try running the diagnostic test below and then write back with condition indication code. -- SWT
DIAGNOSTIC TEST
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select the DRAIN/SPIN cycle.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Indications
C:00
C:01
C:02
C:03
C:04
C:05
C:06
C:07
C:08
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My bosch wfk 2401 when i start the wash everything is fine then after a couple of minutes it starts beeping the error code 01. i have checked to make sure the filters are cleaned out and that the water...
Hello and welcome to fixya.
I'll start by saying you're right the "01" error code is indicating a fill problem has been detected by the control.
Have you tried just a "cold" water wash ? If not try selecting "quick wash" and on the dial turn it to #1 "cold" in the cotton setting see what happens. Do the same and select #3 "hot". If the error occurs in one and not the other, observe and either focus on the hot water valve or the cold main wash valve ( I don't think it is the cold prewash valve or the error would occur immediately ).
In fact I suspect it is the main wash cold valve ( dual valve ) since you haven't indicated the error occurs during prewash and the hot water valve is energized in prewash by design to help rinse out the detergent no matter what cycle or temp. you selected.
Having said all that, here's what you're dealing with. Even though you appear to have sufficient water flow as you stated you checked for, the electronic control doesn't think it is correct.
There are several factor's which could possibly be causing this error, a couple you've mentioned.
They are...
 Water supply turned off. ( obviously not in this case )
 Water inlet hose filters (strainers/screens) blocked. ( you've said you cleaned them out )
 Water pressure too low. ( must be no lower than 14.5psi and a max. of 145psi )
 Water inlet valve(s) has failed. ( this doesn't appear likely...at least at first, not completely failed based on your description...but the control may think it has. If you have an ohm meter you can check it. the coils should have a value of between 2.7 and 3.3k ohms. That means 2700ohms and 3300ohms. If not within those values the control will detect the value being incorrect , hence displaying the "01" error. Change the valve, Bosch part # 265772, or repairclinic.com # 467537.
The Hot water valve if need be is Bosch part # 171295 or repairclinic.com # 423900 )
 Control module has failed. ( Not very likely either...but possible...if not the valves. )
Let me know what you find as I will watch for your reply here. Thanks for visiting "fixya". Please take a moment and rate the info provided for you here today.
Let me know if you require further assistance.
Thanks and good luck.
macmarkus :)
Jun 12, 2010 | Bosch WFK 2401
Bosch washer spin only
Had a repair man here for the same issue. Learned two things:
1. Too much detergent causes 'soap lock.' The electronics will get confused when there's too many suds left after a rinse and shut the spin cycle down. That's why re-running the entire cycle without more detergent solves the problem. Use less detergent.
2. There is a way to manually get the spin cycle to run using diagnostics codes. Here's what my guy did:
a. Washer selection knob in OFF position.
b. Hold the 'Spin Selection' and 'Delay Start' buttons down at the same time.
c. While holding those two buttons, turn the Washing selector knob to Permanent Press-Cold.
d. Keep the buttons held down until the LCD control panel reads 'P:01'
d. Release buttons.
e. Use the 'Spin Selection' button to cycle thru the codes. Stop when it reads 'P:04' which is the spin cycle.
f. Press 'Start/Pause' button to begin the spin cycle.
I don't know what the other codes do but this should save you from having to run the entire wash cycle.
Hope that helps! Tim
Apr 17, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Washing Machines Logo
342 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
