Question about Dell Microsoft Windows XP Home Edition
Computer keeps switching itself off - Dell Microsoft Windows XP Home Edition
  • 6 more comments
  • jrebrown21 Mar 12, 2011
    ok all done
    all done
    I did what you said,
    but has not solved it
    Computer keeps turning off,unchecked the automatic start up button,but not solved it !!!!!
    I will have alook & get back to you
    My computer keeps switching off
  • 2,632 Answers
Welcome to Fixya. Your clients or even your own computer may keep restarting for no reason without warning. First of all, when a computer keeps rebooting it can be caused by a wide range of problems, from incompatable software such as Firewalls and Antivirus software, damaged or overheating parts inside your computer or even incompatable peripherals such as printers and scanners. Here are some computer repair tips to help you diagnose the problem.
When a reboot occurs from within Windows XP, your computer will totally restart without telling you what caused it. This is the default behavior when Windows XP encounters a system failure.
To see what the error was you can change the default behavior by right clicking on My Computer and choosing Properties. Goto the Advanced Tab and under Startup and Recovery press the Settings button.
Under the System Failure box there will be a checkbox saying Automatically Restart. Untick this box and click Ok.
Next time the system has a failure it will show the Windows error blue screen (also known as BSOD, Blue Screen of Death) and it will have an error code, grab a piece of paper and write this code down.
It may look something like this: Stop 0x0000000A or IRQL_NOT_LESS_OR_EQUAL
You can also check to see why your computer had a failure by checking the Events log for error messages. You can see the Event Viewer by going to Run and type eventvwr.
Another cause for random reboots is that the computers processor is getting too hot. To check this, enter the computers BIOS during boot (usually by pressing Delete) and there will be an option about the computers temperature (often under PC Health).
This should show you the current temperature of the computer and the emergency shutdown temperature. The emergency shutdown temperature is a safeguard for when your computer gets too hot it will shut itself down to prevent damage.
You can either raise the shutdown temperature or switch it off completely, however be warned that you may damage your computer if the computer gets too hot. If the temperature was causing the reboots then you should consider getting better cooling for the computer such as more powerful CPU fans and more case fans.
I believe that some steps have been taken and the problem still lies. Try to check if you will be having a BSOD or Check the computer's temperature. If you have questions please let me know.
Thanks for using Fixya
Posted on Mar 12, 2011
  • 2,574 Answers
Could be your cooling fan isn't working. This is what keeps the CPU cool. To know for sure is to remove the panel from the computer and see if the fan is spinning inside on the CPU chip.
  • Reparatii PC - Service IT
    ok.no problem
    Make sure that you have a good power supply.You need to make sure all your fans spin properly. Also, inspect the
    motherboard for bulging or leaking electrolytic capacitors. These failed
    or failing capacitors are a common cause of sudden, but seemingly
    random system lock ups and reboots. The capacitors look like tall soda
    cans, many of which surround the CPU socket.
    Guru:
  • 254 Answers
Hello
disable the automatic restart.
theanks
  • 1 more comment
  • DeadDreamer Mar 12, 2011
    right click your my computer and click for advanced setting and click for startup and recovery and uncheck the automatic restart.
    you need more help? did your problem solved? pls. rate this solution!!!
    thank you
    right click you my computer in your desktop and click for properties and click for advanced tab and unchecked the automatic restart. click ok and its done.
    thank you
    pls. rate and accept this solution
My jbl micro speaker keeps switching on and beeping can it be fixed
It sounds like you have a defective on/off switch. Read through the documentation about resetting the device. You might also try blowing some canned air over the switch while pressing and unpressing the switch. There could be some large particles lodged in the switch.
The first point of mechanical failure is the on/off switch and given the way these smaller speakers are manufactured there is little hope of repairing the switch itself.
Feb 27, 2015 | JBL Audio Players & Recorders
When I am downloading a film...I leave my PC on but when I go back to it after about half an hour it has switched itself off stoopping my download can you help please ty mike
There is little info on your problem but I think you mean the screen went black while downloading a film. Normally computer monitors turn themselves off (dormant) to save energy and the life of the monitor's screen if not used for 10 or 30 minutes, depending on the settings, but the download just keeps going. Mine is set to 10 minutes. All you have to do is disturb the Mouse and see if the monitor screen switches itself on. There is another power saving option, and that is the Computer itself. If the computer is not used for one hour, it too goes dormant, but can also be set to switch itself completely off after the download is completed. However, if a computer is left on for over an hour, it can switch itself off to save energy and the computer's own wear and tear. It all depends on the computer hardware and the settings. If it is hardware controlled, then it may or may not switch itself off but it still goes dormant. Or it can be set to whatever you wish it to do, stay on all the time, go dormant after a set time or switch off if there is no prolonged activity.
Jul 16, 2014 | Computers & Internet
My computer keeps switching itself off and won't swtich back on again? What can be the problem?
Hello
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
Oct 30, 2012 | LG Computers & Internet
Have fujitsu esprimo mobile laptop screen keeps switching itself off intermitantly (approx every 30 secs) anyone know why????
system software is probably corrupted, have it fixed by a capable computer guy or if it is still under warranty have them fix it for you
Oct 25, 2012 | Fujitsu ESPRIMO MOBILE V5515 V5555 V5535...
Tv keeps switching itself off when you are watching it and if there is something you can do to stop it. because this morning my tv kept turning itself on even wen i switched it off, and then this evening...
CLICK HERE for the most common solution to this issue!
If the link doesn't work, copy and paste this link in your browser address bar.
http://www.fixya.com/support/r8558239-lcd_or_plasma_tv_or_monitor_turn_or_stay
Mar 10, 2011 | Samsung SyncMaster P2270 22 inch Monitor
Acer Monitor Not Staying On
It sounds like there's a problem with the monitor itself. It may be that the lamp in the computer is dying, which would explain why it keeps going out. Other possibility is that the monitor isn't receiving power properly either through the cable or inside the monitor itself.
If your're not the kind of person who wouldn't mind opening the monitor up and hopping in there, then I recommend you take it somewhere it can be diagnosed like Best Buy.
Hope I helped :)
Nov 28, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Computer shuts itself off randomly!
Could possibly be a bad capacitor on the board. Or could be overheating. Clean out the inside of the case with some compressed air and double check all fans are operating.
Oct 20, 2009 | ASUS A7V400-MX Motherboard
Computer turns itself on
if you can get into bios check and see if there is any type of alarm or auto on set up. If not or if its not that big of a deal just use the switch on the back of the power supply at night. Make sure you shut down your computer before switching this. It will definately keep the computer from turning on by itself.
Dec 30, 2008 | Dell Inspiron E1505 Notebook
My phone keeps switching itself off
my phone just keeps switching itself off, can anyone advise me on what the issue might be
Nov 11, 2008 | Samsung SGH-D900 Cellular Phone
Computer keeps turning itself off
Does it reboot or just switch itself off? If it reboots it could be many problems with many solutions.
Does your computer feel hot? Check the temperature with a download from http://majorgeeks.com/download.php?det=311 this should monitor your boards temperature once loaded.
Aug 10, 2008 | Packard Bell Computers & Internet
Computers & Internet Logo
59 people viewed this question
Alun Cox
