Question about HP Computers & Internet
How do i install an operating system in a crashed hard disk drive?
  • HP Master
  • 13,433 Answers
If the hard drive is broken you can not - replace the drive. if the drive works as normal, then just use a windows installation disk or recovery disk.
Posted on Mar 12, 2011
How can I get a disk to install in a new hard drive for a Dell computer with Windows 7 Home Prem
Dell will often sell the disks if you did not make a back up before your HD crashed.
Oct 07, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to Install an Operating System on an External USB Hard Drive:
You may have an external hard drive you want to use for more than just document backup.
In this situation, you can install an operating system onto your external hard drive. By doing so, you will be able to run your external hard drive as a fully functional operating system.
If your primary hard drive ever crashes, you will have a backup option unavailable to those who simply use their external hard drives as file and document backup.
1) Plug your external Hard Drive into your Computer using the USB cable. Insert the installation disk for your Operating System into the CD/DVD Drive. Turn on or restart your Computer.
2) Boot from the installation disk. You may have to press a key once prompted to boot from the installation disk.
3) Accept the license terms and conditions. Read through these carefully if you wish to understand your legal rights as a user. If you disagree with these terms and conditions, you may want to purchase a different Operating System.
4) Choose your destination drive. Your external Hard Drive will likely be the E: or F: drive. By default, the C: will represent your main Hard Drive and the D: will usually represent your CD/DVD Drive.
5) Begin the installation. Your external Hard Drive will install the Operating System. You will now be able to run that Operating System off of your external hard drive.
Hope this helps.
on Sep 03, 2010 | Computers & Internet
Why my acer aspire say system not found
The system cannot detect the hard disk drive. Before you start up, re insert the hard disk. Remove the memory card and clean it with soft cloth or tissue paper. After doing these..Start up your computer and see the results. If nothing happens, restart your laptop, hit F12 key & set the hard disk drive to first boot device then press the Enter key. wait till the OS comes up.
Aug 19, 2014 | Acer Aspire 4720 Notebook
Flashing folder when i turn on mac
Your hard drive may have crashed or it's settings have changed so it is no longer recognized as a startup (boot) drive. Try starting from your original operating system CD. (or borrow one). Press the C button at power up to force your computer to start from the CD.
Once started, don't install the operating system. Go to the pull down menu's and select Disk Utility. If Disk Utility sees your hard drive, select it and run the repair disk program. If it doesn't see it, your hard drive has likely crashed. You will have to replace it, install a new copy of the operating system, and likely have lost all your data and documents. This is where I would start.
Mar 08, 2014 | Apple MacBook Pro Laptop Computer with...
How to install os in usb hard disk
First plug your external hard drive "disk" into your computer using your USB cable. Then insert your CD/DVD in your CD/DVD Drive "D, or E, or F" that are define in your system and turn off your computer and On your System "computer". Then boot form the installation disk. Begin the installation so that the hard drive will install the operating system. Then accept the license terms and conditions. Then choose your destination drive."By default, the C: will represent your main hard drive and the D: will usually represent your CD/DVD drive. So your external hard drive will be the E: or F: drive. "And you will now able to run that operating system."
N.B: "You will be able to run your external hard drive as a fully functional operating system. If your primary hard drive ever crashes, you will have a backup option unavailable to those who simply use their external hard drives as file and document backup."
All the Best!
Oct 18, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
My gate way went down now it tell me no operating system found what do i do
Do you have a cd/dvd in the drive? (a non-system disk)
Try to boot into safe mode.
Try to restore to an earlier time.
If unsuccessful ... you may have to reload the operating system
Oct 21, 2009 | Computers & Internet
Missing recovery disk for Composer 5100
The recovery disk is usually stored as a separate partition on the hard disk itself (Mostly in cases of laptop disks), so when ever you purchase laptops with pre-installed Operating System, The very first thing you do is create a CD/DVD recovery disk ie burn the recovery partition on the CD/DVD.
so that you can use the same DVD in case the OS crashes.
In your case as your hard disk was crashed and replaced ask the people from where you purchased the laptop/pc to restore it to the new hard disk, or purchase the Operating System.
hope this clears the doubt
regards
Jun 22, 2009 | Computers & Internet
Display hardware or drive broken
format your laptops's harddrive and install the operating system. When computer crashes very often, it is better to format it and install the operating system. Don't opt for quick format. This will help you to detect bad sectors. If there is bad sector, you have to replace the hard disk.
Jan 30, 2009 | Acer Aspire 5920-6727 Notebook
Bad disk
agri-man
low-lable format can solve ur problem.
at first create windows98 startup disk from any win98 pc or use windows98 bootable cd. and download disk manage 9.54 for samsung hard disk. and copy it in a cd. then boot ur pc with windows98 bootable disc or startup disk. then inseart disk manager cd go to cd rom drive give "dm" commnad. run low lable format form advance --->utility ----->maintanance------> low lable format. after complete low lable format (it can take saveral time) then creat partition and format each partion.
Jun 25, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
