Question about HP Office Equipment & Supplies
Hp psc 1110 all-in-one throws up this message when plugged into laptop power surge on hub port A USB device has exceeded the power limits of its hub port
  • annbrassey Mar 12, 2011
    accept that this is a laptop problem rather than the printer
  • 34 Answers
Your laptop is causing the issue and not your printer. You can try to use a USB hub and connect your printer in it so that the power distributed from your laptop's USB port is dissipated to your USB hub even if the printer is the only one that is connected to it. This is because of a faulty USB port in your laptop especially if it's still the old USB 1.1 type.
Posted on Mar 12, 2011
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Mar 11, 2011 | HP Compaq nx6110 PC Laptop
Power Surge error message
can you please detail the exact name and model of your hub..?
Thank you
May 13, 2008 | HP Pavilion dv4000 Notebook
Power Surge on Hub Port
hi, Please reinstall the chipset drivers and "Turn off the error messages from Device Manager => USB Host Controller => Advanced Tab => check mark "Don't tell me about USB errors"
Jun 12, 2009 | Compaq NX6110 TFT XGA Notebook
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge on hub port message
Use a powered hub, one that has it's own power supply.
May 09, 2009 | Microsoft Windows XP Home Edition
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
Usb power surge
The Safely Remove Hardware icon list all removeable devices regardless whether it is a USB or PCMCIA or a removeable CD/DVD drive etc.
To get around the problem with your USB device that exceeds the power limit of the computer's USB port. Get a powered USB hub and connect it to the computer's USB port and plug the USB device into the powered USB hub.
Apr 06, 2009 | IBM ThinkPad T30 2366 Notebook
I have Hp Compaq nx 6110 Laptop everything is ok boot system normal no any error but just laptop move any where then system stuck and only way of power off and second problem is "power surge on hub port: a...
1st prob. - I appears there is a loose connection problem somewhere - try reseating your RAN and hard disk.
Try to determine which part of the laptop is causing the problem, not moving the laptop around the room but by flexing different parts of the laptop and power cable etc. while it is on your table.
2nd prob -
Some USB devices draw more power than the USB port can provide and you get the error message - "exceeded power limit".
In these cases you will need to purchase a powered USB hub, connect this hub to the laptops USB port and connect the offending USB device into the powered USB hub.
Mar 31, 2009 | Compaq NX6110 TFT XGA Notebook
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
53 people viewed this question
Seeker5211
Seeker5211
