Question about Bosch Classixx WFL 2066 Front Load Washer
Classixx 1200 - when I start a 40degree wash it sticks at rinse cycle, rinse light flashes but nothing happens If I manually start a rinse/freshen up cycle it works fine - all pipes seem ok, water getting in and draining, all filters seem clear
  • peterh128 Mar 12, 2011
    Thanks - looking at relative cost of repair vs replace - how much are parts/fittng likely to cost for both?
  • 4,323 Answers
Hi
The issue seems to be either with the pressure switch going bad or the timer is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 12, 2011
  • Daniel Scott
    Daniel Scott Mar 12, 2011
    Will cost around $250....
Why does my Bosch Classixx 1200 Washing Machine rinse if I turn switch to rinse but will not rinse when automatically.
Are you on a delicates program that has no spin or is there a no spin button that has been pressed?
Check the manual to see what programs do what. You can usually find a manual on line if you have lost yours.
Dec 13, 2014 | Bosch Washing Machines
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
Hi I have a bosch classixx 6 1200 express. I cleaned the filter a 2 weeks ago but there was hardly anything on it. It is going through the wash down to the last minute but still like as if it is still...
Sounds like motor is not turning drum....could be due to worn motor brushes, you need to remove the motor to check this ,if not too handy advise you call engineer........
Jun 13, 2011 | Bosch Washing Machines
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch Classixx WFL 2066 Front Load Washer Logo
87 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
