Question about GE AJCQ08ACB Air Conditioner
Not draining Water is spitting out of the front of my GE air conditioner and does not appear to be draining. Where is the drain?
  • Ken Bledsoe May 11, 2010
    has this been addressed yet
  • 478 Answers
It has to be angled slightly toward the back to the pan under the bck coils and out to the outside, good clean water great for plants and pets.
Posted on Mar 29, 2009
Why is my air conditioner spitting water back in the house. These do not have ourside drains on them?
Take the front cover off and use a shop vac to suck the water out, check filter while you do this see if the evap coil is dirty the one on the inside. sounds like it maybe freezing up. check for air flow.
Sep 06, 2014 | Haier Heating & Cooling
Why does my air conditioner spit out water and gargle?
during the monsoon the humidity buids fast on you coil there is a drain plug you can open or hook a piece of pipe from the drain plug that will solve the problem forever
Aug 25, 2012 | GE Heating & Cooling
GE Airconditioner is leaking water from inside
You could try drilling a hole in drain pan so it drains outside.
Aug 23, 2012 | GE Heating & Cooling
My LG air conditioner is spitting out water and making a weird noise....i took off the front panel and theres a lot of water in what i guess is a condensation pan....ive tried drying the little bit i can...
Go around the back side and unplug the drain hole! These are designed to drain out the back through a hole in the drain pan. Maybe your unit is tipping forward and not draining like it should. You can use a coat hanger or wire or even a shop vac to remove debris from the drain.
Aug 15, 2011 | LG Electronic Window Air Conditioner
My GE window unit air conditioner isn't blowing out very cool air,and it spits what
From what you have described, it sounds like the drip pan under the unit is full of water. This can be caused by the unit not being installed properly in the window. It must have 1/4' to 1/2" downward tilt at the rear. This allows the water in the drip pan, to flow to the rear and drain away thru the drain hole. Also, the drain hole may be clogged and needs to be cleared. The drain hole can be a challenge to find sometimes, as the clog can blend in with the hole. Be patient and persistent when looking for the drain hole. A pipe cleaner can be used to clear it.
I hope this helps and thanks for choosing FixYa.
Aug 04, 2011 | Goldstar LG LW1804ER Window Air...
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
It collect in the front of the unit. I put a small
the unit needs to tilt back a little so the condensation can drain also remove front cover and check drain pan is clear of debris so the water can flow back and out of drain
Jul 23, 2010 | LG LB1000ER Air Conditioner
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Jun 25, 2010 | LG Electronic Window Air Conditioner
My Lg split system air con spits water
Make sure the unit is tilted downward at the back. About 1" lower than the front is good. Even with a drain, the water will pool inside if it doesn't have a slope for drainage.
Feb 19, 2009 | LG LB1200ER Air Conditioner
GE AJCQ08ACB Air Conditioner Logo
533 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
