Question about Vizio VO22L 22 in. LCD TV
Vizio VO22L blue screen with "no Signal" message. Dish signal is OK, other TV works at that location. have tried System Reset with no results....
  • 19 Answers
SOURCE: Vizio L37
try to go to the menu,then find the words,blue on or off,turn it off,then you will see the changers.
Posted on Nov 10, 2007
SOURCE: Vizio "no signal"
We just had this problem and it was the cable that came with the set. Once we replace this, it received a picture, however, now the volume and on/off does not work on the Verizon remote.
Posted on Mar 09, 2008
SOURCE: Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Posted on Nov 03, 2008
VOTIT
  • 2071 Answers
SOURCE: I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Posted on Apr 23, 2009
  • 10 Answers
SOURCE: Vizio won't turn off
This could be a mainboard problem. Sometimes one of the fuses may be bad and may freeze up causing the TV to not be able to power off.
Posted on May 23, 2009
I get a message that says "No Signal"
Tuner fault or the Ariel connection is not correct.
Gopakumar Gopalan Google
Jun 26, 2015 | Vizio VO22L 22 in. LCD TV
Inputs don't work
more likely faulty tuner. have to take it to a repair shop, ask for quote , if the set is old may be cheaper to buy a new one.
Jun 26, 2015 | Vizio SV421XVT 42 in. LCD TV
HOW DO I GET A CHANNEL ON MY TV AND GET THE MESSAGE "NO SIGNAL" OFF THE SCREEN?
If it shows "No Signal" it means it. It do not get any signal to display. Check all the settings. Refer its user manual for details. First, try to tune it to on-air program, by do an auto-tune function, after connecting it to an external antenna. Refer its user manual for more details. If it do receive all the channels transmitted, means, the set is OK, and the fault will be with the input selection, you've done. OK?
May 02, 2014 | Vizio Televison & Video
I have no signal with I turn on my tv, I have dish. It is on channel 3.
tried to reset first the dish then check if it can get signal now, if still no signal receive you can hooked up the dish to the other tv just to ensure if the cause will be in the tv. just let me know if it works, if the same problem the cause will be the dish has a problem.
Nov 08, 2012 | Vizio 42 in. LCD TV
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
I can not get TV to pick signal from PC
I had a problem where my VO22L was giving me a "No RGB Signal" "The Power Will Be Turned Off" message when I had it in RGB mode (with VGA input from my PC). Anytime I left my PC on and turned off the power of this unit, I got this message. I just got off the phone with a very friendly and patient Tech Support woman at Vizio, who talked to several different techs who all came up with things that didn't help. Finally, while we were talking, she came up with the idea of going into the settings menu and doing a "System Reset" to see what happens. What do you know, it worked!
To anyone else having this problem, try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote. The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". I powered the monitor off and on, and the problem is gone. Now if it happens again, I know what to do.
Apr 08, 2009 | Vizio VO22L 22 in. LCD TV
RGB NO INPUT SIGNAL
RGB stands for Red Green Blue. Your monitor isn't getting a video signal.
First, look behind your PC.
Pull the video plug and check the pins.
The should be three rows of them. Make sure none of them are bent over.
On the back of the PC, look at the connector socket you just pulled the plug out of. Is there another like it? (15 holes, 3 rows of 5)
If so and the original doesn't work, switch the plug to the other.
Put the plug back in and screw it in tight.
Reboot your PC.
Hope this helps,
Mike
Jul 12, 2008 | Computers & Internet
42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
Apr 15, 2008 | Vizio GV42L 42 in. LCD Television
Vizio VO22L 22 in. LCD TV Logo
52 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
