Question about Buffalo Technology 250GB USB SATA 2.0 HD 250 GB Hard Drive
Buffalo+250 hd-hb ou external drive , starts but wont show its content "syas You must formate Your Disk, Is disk broken ? Is it a software problem ? Can You Fix broken disk ?
Crankstart
  • 696 Answers
SOURCE: My PC frozen when I connect Buffalo Technology 250 GB HD
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 08, 2009
  • 130 Answers
SOURCE: my buffalo external hard disk
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Posted on Apr 13, 2011
  • 6 Answers
SOURCE: My buffalo HD 250 has
1. Call this number to find out if u still have warranty on the product. 866-752-6210 2. if you do they MFG should replace it for free of charge.
or if u don't there is now you can fix it because it burnt the whole circuitry in the hard drive.
Posted on May 03, 2011
  • 21 Answers
SOURCE: PROBLEMS WITH BUFFALO EXTERNAL HARD
psp
Posted on May 13, 2011
bronk50
  • 27725 Answers
SOURCE: 500gb buffalo external hard drive
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Posted on Jun 12, 2011
External HD isnt recognized by ps3
Hmm, go to Start, Control Panel, Administrative Tools, Disk Management. Then look or scroll down right hand panel to find your disk. If it is there you could RIGHT click on it and assign a new drive letter such as Q or R.
If it's not there your external disk could be faulty, the power supply transformer or power cable could be faulty or it could be the USB cable.
If all looks OK you probably need to contact a disk recovery specialist such as DATA365.
Comment: NTFS is a much more stable file system and is much easier to recover after errors. FAT32 is not commonly used now.
Dec 08, 2013 | Buffalo Technology Computers & Internet
Need to format my portable HD (Buffalo 3.5 500GB Mini-station) before using as External HDD for my TV (LG 42LA6200)?
BUFFALO TOOLS Buffalo Tools is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.
Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Only basic external hard drive functionality is supported with this operating system; some included utilities may not work. The HDD default format is NTFS; to work with Mac, reformat the HDD using Mac Disk Utility.
I would plug it into a windows 7 or Vista and the computer's USB. The computer should recognize it. Click start then computer and find the icon for your drive and right click your Icon. In the drop-down window look for 'format' and that should help you format your drive. is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Oct 21, 2013 | LG 42" 6200 Series LED HDTV - 42LA6200
File size limit for Buffalo HD 250 GB Hard Drive backup
The file is too large meaning that the size of that SINGLE file is too large. Your hard disk is probably formatted to a FAT32 file system, this results in a maximum of 4gb PER FILE maximum transfer. What you could do is archive it into a few parts using winrar and then moving it onto the disk, and when you need the file just extract the archive. Your problem isn't the total free space, it's the size of that file chunk.
Nov 03, 2012 | Buffalo Technology 250GB USB SATA 2.0 HD...
I could not dump files while it was as FAT32 format. I then formatted the HD to NTFS and the same issue persist. Now there isn't a "format" option when i load the HD. The model i have is PXT320U2
http://support.microsoft.com/kb/309000
Access Windows Disk Manager to see all the drives that are currently connected to your computer. From there, right-click your external hard drive and you should be able to reformat it.
Feb 28, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
Every time I connect my Buffalo Hard disk (HD-PE320U2) and try copying data it shows IO device error. I don't know what to do! help me. Formatting did not help!!!!
That error signals the fact that the motherboard can't communicate properly with the controller of the disk. It's a hardware fault and it's unfixable - this disk is dead, replace it.
Feb 07, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
External Buffalo Hard Disk 500 Gb model no HD-PF500U2/BK-AP not detecting when connnected to a laptop or a desktop PC
Check the usb port function in the computer bios settings and be sure that it is set to yes. Connect properly your external drive. If it has two wire usb connections, use both to obtain the maximum power that will be need by your drive.
Dec 18, 2009 | Buffalo Technology 500GB DRIVESTATION...
HDD is not dedected.
the first thing that pops up in my mind is a power problem. check if the hard disk starts making a 'spinning' noise when you plug in the power chord and turn the disk on. when you hear a ticking noise instead, it means the disk is broken. be sure it only makes the spinning noise. if it does, connect the usb-cable between the disk and the computer. if the disk is not recognised, replace the cable. if still not ok, post what you did as a comment, and please be as accurate as possible, because this problem may have several causes.
Jun 22, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Buffalo Technology 250GB USB SATA 2.0 HD 250 GB Hard Drive Logo
95 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
