Question about Nintendo Wii Console
My wii (wii nintendo model no. rvl-001(kor) facing a problem. error is to always to eject and see manual to troubleshoot.
5 Suggested Answers
SOURCE: power light went out and won't come on. Hasn't
wii control doesn't turn lights on. if you twist it a bit, the lights go on. must have something a bit los inside. no tec service here
Posted on Sep 13, 2009
  • 839 Answers
SOURCE: My Wii RVL-001 will not
check these things >>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
still the same problem,dont worry check out the following Repair Guide....
click here to download repair guide
Posted on Dec 26, 2010
askme1
  • 113 Answers
SOURCE: nintendo wii error message.
Usually this error happens when the console is dirty or the drive needs to be replaced... try cleaning the unit with a cd cleaner and a can of air... also check to see if any other cds work in the unit... if not then replace the DVD drive
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Posted on Feb 09, 2011
  • 53 Answers
SOURCE: I can't connect my controller
  • Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote.
  • If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
  • If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
  • If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
  • Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
Posted on May 13, 2011
Model rvl 001
Netflix is not pre-installed on the Wii. To install it, launch the Wii Shop Channel and click "Channels", then select it from the list (it is a free download).
Jan 31, 2014 | Nintendo Wii Console
Is it beyond repair if plugged in to 220V, but not used?
The higher voltage has burned out the unit. A step down transformer had to be used with your device.
Sep 20, 2017 | Nintendo Wii Console
Wii error code 4
Try connecting to a different Screen and if the problem follows the Wii... then you have your answer
Apr 11, 2013 | Nintendo Wii Console
My Wii will not let you insert any discs.
Discs Eject on Their Own
Situation:
Game disc is ejecting on its own
Applies To: All Games
Important!
If the game disc is ejecting on its own, this could indicate a problem with the disc or with the disc drive.
What To Do:
If you are experiencing this problem while attempting to play a Nintendo GameCube Game Disc, check the model number on your Wii console. Only Wii consoles with model number RVL-001 are compatible with Nintendo GameCube Game Discs. (learn more)
If the issue is occurring with all games or all of one type of game (Wii or GameCube), this indicates a problem with the system. To begin the repair process, click here.
Nov 16, 2012 | Nintendo Wii Console
Where can I find a user manual for my Wii RVL-001 (USA)?
These work for all type of wii models
http://gamesites.nintendo.com.au/support/Wii_Operations_Manual-SystemSetup_AUS.pdf
Thanks
1RepairStop.com
Feb 15, 2012 | Nintendo Wii Console
The wii won't read the disc
Situation:
  • System displays either error message "Unable to read disc" or "Disc could not be read"
What to do:
  • This message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
  • If the Wii console is laying flat, verify that the system is not placed upside-down. The game disc slot should be above all three buttons and the SD Card slot.
  • Verify that the disc is being inserted properly.
    • If the console is placed vertically, the disc label will face to the right. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically (learn more)
    • If the console is placed horizontally, the disc label will face upwards.
  • If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
Situation Not Resolved:
  • If only one Game Disc displays this error message, it will need to be replaced. Click here for Game Disc replacement options
  • If the error is occurring with most or all Game Discs or all of one type of game, then this indicates a problem with the system. The console and one or two example discs will need to be sent in for repair. Click here to begin the repair process.
function rvl_ts_sys_unable_read_disc_showsurvey(){ omnitureHelp("helpful_survey:rvl_ts_sys_unable_read_disc",JSchannel,JSprop6,"",""); } var req; var timeout; function rvl_ts_sys_unable_read_disc_psurv(a,sid,pid){ if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); if(a=="yes"){ document.getElementById("rvl_ts_sys_unable_read_disc_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_unable_read_disc_s_no_button").innerHTML=""; } else{ document.getElementById("rvl_ts_sys_unable_read_disc_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_unable_read_disc_s_no_button").innerHTML=""; } var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid; req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_unable_read_disc_psurvr; req.send(null) } function rvl_ts_sys_unable_read_disc_psurvr(){ if (req.readyState == 4) { if (req.status == 200) { clearTimeout(timeout); var outString=req.responseText.substr(req.responseText.indexOf("##")+2); outString=outString.substring(0,outString.indexOf("##")); document.cookie='rvl_ts_sys_unable_read_disc=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/'; document.getElementById("rvl_ts_sys_unable_read_disc_s_folowup_div").innerHTML=outString; } } } function rvl_ts_sys_unable_read_disc_techDif(){ //it broke document.getElementById("rvl_ts_sys_unable_read_disc_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us."; } function rvl_ts_sys_unable_read_disc_clearboxsurv(whatto,box){ if(box.value==whatto)box.value=""; } function rvl_ts_sys_unable_read_disc_fsurv(form){ var url="/consumer/surveys/surveySubmit.jsp?p=7" var reasonSet = false; for(var i=0;i-1)reasonSet=true; }else if(form.elements[i].name.indexOf("question2_answer")>-1){ url+="&"+form.elements[i].name+"="+escape(form.elements[i].value); }else url+="&"+form.elements[i].name+"="+form.elements[i].value; } if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;} if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_unable_read_disc_psurvr; req.send(null) } Was this information helpful? yes.png no.png
Dec 25, 2011 | Nintendo Wii Console
My WII will not read any disk and we do not have a menu. All it will say is unable to read disk.
Unable to Read the Disc / Disc Could Not Be Read Situation:
What to do:
Our one is less than 1 year old. The screeen says 'An error has occured, eject the disc turn off the console and consult the trouble shooting section of the operations manual' What do we do? Model...
This is an extremely common problem with the Wii. The disc drives in them had quite a high failure rate and it sounds like yours has this. Because the Wii is under 1 year old it is still covered under Nintendo's guarantee and if you contact them they should replace it free of charge.
Sometimes this can also be caused by dirty discs, just make sure they are all really clean as the Wii disc drive laser is very sensitive to dirt.
Hope this helps
Dec 05, 2010 | Nintendo Wii Console
I can't get the hand to show up on the screen. Wii fit nintendo 2006 model model # rvl-001(USA)
Check to make sure your light-bar is plugged in securely (the thin sliver bar that you put on top or below your TV). The wire for this is quite thin, so make sure there are no punctures and cuts in it. I hope this helps!
Here is a link to Nintendo support:
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Here is their support phone #: 1-800-255-3700
Oct 12, 2009 | Nintendo Wii Fit for Wii
Nintendo Wii Console Logo
392 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
