Question about Samsung Televison & Video
The remot has quit,to my bravia samsung and the battery is good
  • 718 Answers
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
If you do then the problem might not be the remote but the sensor on the set.
For replacements;
In the USA look at; eBay or www.remotes.com
In the UK look at; http://www.espares.co.uk
Posted on Mar 12, 2011
My remote has stopped working
Try some new batteries - they do wear out.
Aug 03, 2017 | Televison & Video
My control remote sony bravia lcd not funcion, model RM-GD004
At first, check if battery contacts inside the battery compartment for any dust of rust accumulated. Clean them well, and insert fresh batteries and check. Check its infrared emission. You can check it by using a cellphone with camera option. If there is no infrared emission, you have to check its infrared LED at the front of the remote control for damage or loose solder terminals. For this, you have to open the remote control. If you wish to get more details about how to check and clean a remote control, visit this site. It has a post, that describes how to clean a remote control. Good luck.
Feb 07, 2013 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
My tv remote quit working for a awhile then it started working again then it quit again i have tried universal remotes but none will wok my tv
You need to fix this your self, take the batteries out from the remote control, take something sharp like knife, and clean the springs where the batteries are placed, all of them needed to be cleaned. Try to check if this does work, if not then, take a flat screw driver, open the remote cover gently and use a bit of alchol or any solution, to clean the pcb board. Try to fit things back and check the remote again..this should work. We had done to most of remote control..it works...good luck.
Sep 17, 2011 | Samsung Televison & Video
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
My RM-YD028 Sony BRAVIA Remote Control has stopped working, how do I reset?
Remove the batteries from the remote and wait 5 minutes or more. After waiting, insert the batteries again. The remote should now work. If it's still not working, the remote is probably defective. If that is the case, please contact Sony Customer Support, which will be able to assist you in getting a replacement issued.
Jun 01, 2011 | Sony Bravia Remote Control 148016611
The remote control does not work changed batteries
Either the sensor in the lower left of the set is blocked, dirty or it has failed. The remote for the set can also be checked at a place like radio shack or the dealer you purchased it from/ It is possible that that remote quit and the new on is not recognized by the tv. If you have another Sony tv you can try the remote on that and see if it turns off and on with the old remote, I believe most sony remotes at least work on the off and on function.
Feb 15, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My sony bravia 46' KDL3000 upon start up has horizontal lines going accross the screen that make the image blurry.after quite some time it seems to clear itself up and go away almost like once its warmed...
sony lcd blury when we view satelite its common samsung and panasonic give good pitchure then sony bravia tey some good monster cable it will give good pitchure
Jan 08, 2011 | Sony Televison & Video
My Sony Bravia KDL-40D3000 no longer responds to the IR remote. I also have a 46 inch Bravia, and the remote does work with it. The front panel controls work okay. The remote worked for about 2 years, then...
Had the same problem. The infrared receiver quit working. Could not use the factory remote or the cable remote. Simple fix- I just cleaned the infrared receiver. Both remotes now working.
Mar 27, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia 46" remote control turns on the TV but no other buttons work
First, change the batteries on the remote with e new set of batteries. Check to see if you can bring up the menu using the buttons on the TV itself. Let me know what happens
Sep 25, 2008 | Sony BRAVIA KDL52XBR2 Television
Remote control
Did you put fresh batteries in? I know that is "obvious" but it is a common mistake to expect the included batteries to always be good.
Apr 09, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Televison & Video Logo
35 people viewed this question
Jerry Greenberg
Jerry Greenberg
