Water is left in dispenser after load done - Washing Machines
    Brigadier General:
  • 6,277 Answers
Although you do not say which model it is, this is a common problem with many machines.
I suspect that it is a blockage in the conditioner/softener tray and needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Posted on Mar 12, 2011
Water is still in my liquid bleach dispenser after load is finished. is this normal?
If it is just water then it could be OK. Most companies use a water stream to flush the bleach and also the fabric softener out of the dispenser systems and into the washer tubs. Some water left over is probably normal as long as the bleach or fabric softener has dispensed.
Sep 19, 2014 | Kenmore Oasis153; Agitator 4.5 cu. ft....
Why does my Electrolux #EWFLW65HIW have water left in soap dispenser
Good Afternoon Friend,
I understand that your Electrolux washer, model# EWFLW65HIW, has water left in the soap dispenser. This is typical for your particular model. The soap and fabric softener area are set up on what is called a siphoning system. This means that when it is time for the soap to release it will release and run water through the area. If the mechanism closes before the water is done running through, you can have water left in the soap dispenser. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Electrolux Washing Machines
Lg 1370 slight clean water leak on left side of dispenser draw sometimes? solutions please ,
Usually a sign that you are using too much detergent. Pull the drawer out completely and clean it out. The drawer and the casing
May 28, 2014 | LG WM-2277HW Front Load Washer
Water left in fabric softner area when load is done
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Feb 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water left in fabric dispenser after load
The dispensers work by the siphon principle. You load the softener and at the proper time, the machine diverts water to the softener cup raising the level. In the softener cup, there is a tube loosely covered with a cap. When the level in the softener cup is raised high enough, a siphon effect is started and the softener is pulled from the cup into the washer. This will continue until the water quits flowing and air gets under tha cap, breaking the siphon. The amount of water remaining in the cup is dependent on the level of the cap, and the amount of residual water remaining in the dispenser fill tube once the siphon effect is broken. You can see this effect for yourself: take a measuring cup and slowly pour water into the softener cup, raising the level above the max line. When the level gets high enough, the contents of the cup will dispense. You can remove the cover cap that is a part of the dispenser and clean it; it will help. Removing the entire tray and cleaning all of the tubes and the cap assembly will also help. The only other thing that can be done is to change the dispensing supply valve, as it sounds like there may be some leak by after the fabric softener is dispensed. Having residual water isn't really hurting anything. It's only water, and the machine has dispensed the softener! Try the cleaning part first as this usually corrects the issue, and then the repair technician if it still bothers you. For as much as the extnded warranty costs, you should be completely satisfied with your machine.
Best regards, --W/D--
Sep 13, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
Apr 26, 2009 | LG Washing Machines
Water being left in the dispensers when the washer cycle is done
Water in the fabric softner slot is normal, but for the detergent slot you have to clean out with a tooth brush if you can't get the tray out. If there is water there it is quite a serious block, which is affecting your wash.
Mar 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Detergent dispenser is filled with water after wash is completed.
The water is left there because the syphon action is not working in the dispenser, what you need to do is to remove the dispenser drawer completely and thoroughly clean the conditioner compartment, poking any holes or tube, particularly the syphon tube with a piece of flexible wire or similar to ensure it is completely unblocked.
. to test, fill the conditioner compartment with water, and it should slowly empty itself, if it does not, then it is still blocked.
Plz rate this solution.Thanks.
Dec 27, 2008 | Bosch Washing Machines
Soap dispenser not working
It sounds like the water valve has a clogged filter.  Shut the cold water to the washer off, disconnect the hose and remove the filter screen in the washer water valve.  Clean out the filter with toothbrush.  Reinstall and everything should be ok.
Feb 18, 2008 | LG WM-1485FHD Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
