Question about Dishwashers
The wash motor run about at half speed and overheat
  • 28 Answers
Sounds like the motor bearings,,,or motor bushing's have siezed,,,check supply voltage also,,make sure its getting proper voltage,,,but more than likely,,,replace motor.
Posted on Mar 12, 2011
No fast spin at end of cycle
You may have burned up the motor's starter windings. About the time it eases up to speed, the motor overheats, and shuts off. Five or so minutes later, the overheat switch resets and it attempts to start the spin cycle over.
Jun 02, 2015 | Washing Machines
Machines 510
these machines can get seized bearings, which can stop the bowl from turning at full speed. probably the motor after this.the clutch should affect full spin speed only if it's worn. this fault can be a timer issue also.
Nov 17, 2013 | Hoover Washing Machines
Motor humms but wont engage
The start capacitor or start winding has gone bad. Or bearings are dry.
Don't run motor if it does not rotate full speed or motor will overheat and go bad.
Replace or repair motor.
Each motor has 2 winding circuits.
Start winding and run winding.
Both windings receive power same time.
Start winding has capacitor that releases sudden burst of electricity that starts motor rotation. Kind of like low speed on transmission.
Run winding then brings motor up to speed.
http://waterheatertimer.org/images/Motor-wiring-500.jpg
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Nov 07, 2012 | Pool & Spa
What powers the cooling fan motors my ac is not cooling properly the motors come on, but they are not turning fast enough. got straight power to motors, they both work ok.
you may find that the cooling fans only run at half speed when the a/c is on they might be set that way & run at full speed when the engine starts to overheat (in stop & go traffic) the a/c may need regassing that's why it is not cooling properly.....hope this helps...... cheers..
Aug 08, 2010 | 2005 Kia Spectra
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Dishwasher runs for appx 14 min & stops washing half way thru wash cycle. Timer contunies to run. No drain pump out (nothing). Let dishwasher set idle for appx 1 hour and it will re-set. Set timer...
This sounds like something is stuck in the drain pump. You can remove the inner cover to look for obstructions. You have a dual purpose motor it does the both circulating and draining. The blockage is causing it to overheat and trip the thermal protector. You can remove the drain assembly from underneath if you don't find anything from above. There is a video at www.appliancehelponline.com/servicemanual.html that walks you thru most of this. It is a different model but pretty close.If you find no obstructions the motor may be failing.
Apr 08, 2010 | Whirlpool DU840CWD Dishwasher
Will not come up to speed in spin cycle
the motor has two speeds one for washing and one for spinning sonuds like the high speed went out in motor. which is a bummer cause your looking at almost half the cost of the machine to repair
Mar 30, 2010 | Samsung WF337AA Front Load Washer
Spin half the speed
Hi.
Depending on the make and model, and type of washer, you may need to test and eventually replace the following parts:
On top loads:
Variable speed motor .
Motor coupler.
Transmission.
Control board.
Motor control unit (if present)
On front load :
Motor coupler.
Control board.
Motor control unit.
On top load the problem is often transmission or variable speed motor. On front load MCU or motor.
Dec 14, 2009 | Washing Machines
Modle 80 washer question?
ck motor wiring connection for burnt or dark connections also possible bad timer ..have known timer to cause motor to run both speeds at same time this causes motor to overheat and shut off
Aug 16, 2008 | Kenmore 22422 Top Load Washer
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
Owen Barnes
