Question about Refrigerators
On this Frigidaire water filter system, there is a filter state light, wich was red when i bougth the frige second-hand, changed to green, when i changed the filter, normal, but it stays green, even after eleven months of daily use. How does-it get to know when the filter is to be replaced. Should i believe this gadget and wait until it gets red or change the filter like it says on the box after more then 9 months?
  • 22 Answers
HI, if yours is similar to mine with ice maker and gets used several times a day my light comes on about every 6 mo. but i do have three kids so i use a lot of water. depending on use it could last 11 mos. but i would not go past a year if not used as much.
Posted on Mar 12, 2011
How to reset the order filter feature
Good Afternoon Friend,
I understand that the order filter light is showing on your Frigidaire refrigerator, model# DGHF2360PF, and you want to know how to reset it. What you will need to do is press and hold the Water Filter button on the Ice & Water Dispenser control panel for three seconds. When the display changes from Red to Green, the status has been reset. I hope this is helpful.
-Best regards-
WP
May 15, 2014 | Frigidaire DGHF2360PF Gallery 22.6 Cu. Ft....
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
I have the frigidaire refrigerator & I replaced the water filter ,how can I rest the water fliter into green light?
Press and hold the filter reset button on the front of despensor 10-15 seconds until the green red and orange lights come on.
Jun 03, 2011 | Frigidaire FRS26RLECS Side by Side...
I just replaced the water filter in my frigidaire and every time i press for water it flods out of the filter
I had the same problem when I went to change my water filter. Once I changed my filter - the water now gets backed up in the system and water now leaks through my filter into my refridg. I have to take out the filter to stop the leakage. I call fridgeaire and they said every time you replace the filter you have to purge the water system by taking out the water supply in the back of the frige - pruging the system then replace the filter. This still hasn't worked and in my opinion a defect in the fridge. Please let me know if you heard any solutions.
Oct 06, 2010 | Frigidaire FRS26R4A Side by Side...
Change filter light
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
I have a side by side Fridiaire FRS6R5ESB. I came
I solved my own problem. Just realized the red & green dots are not lights
The only LIGHT is the top signal light marked " water filter." which is green
when filter is ok & turns red when filter needs changing. The red & green
dots are not lights but are indicators for the water filter light. Red dot meaning
"change filter" and the Green dot means "filter ok"
May 01, 2009 | Frigidaire FRS6R5EMB Side by Side...
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
