Question about Karcher Garden
Major leak Model K 2.54 M - Karcher Garden
Replaced fuel lines,vent line is my major problem!
Make and model please.?
Where is the fuel leaking from exactly?
Generally you don't get diagrams od fueling routes. They often go via the most direct route from tank to carb/primer
May 26, 2016 | Garden
How many cm to one inch
2,54 cm in each inch.
Try to switch to the world standard in metrics. In the beginning it looks difficult, but everything in science is easier in metrics.
It kost me some time to switch, but I'm glad I did.
I had to calculate Fahrenheit to Celcius and later to kelvin. Inches to mm and cm and so on, but now I only use metrics.
Apr 25, 2015 | Office Equipment & Supplies
How much to fix a power steering leak
It will be according to the Make , Model and Age of the vehicle and which part is broken or which pipe is leaking .
Try to look and see where the leak is coming from before contacting anybody. If you can identify which part it is it will be easier to get an estimated price.
I would contact several local back street garages rather than a Major dealer.
The major cost is whatever the Labour charge is to end up for the removal and refitting of the faulty part..
Some parts may be available at a breakers yard or try a Motor Factors to give you an idea of price.
Although you could ask a dealer for a price as a comparison.
Mar 01, 2015 | Cars & Trucks
Convert 3 inches to metric
1 inch = 2.54 cm so result is 3 x 2,54 = 7.62 cm
Feb 20, 2015 | Office Equipment & Supplies
175cm to inches
1 in = 2,54 cm (to 3 decimal places)
175 cm = ( 175 / 2.54 ) inches = 68.9 inches
Feb 15, 2015 | Office Equipment & Supplies
11 cm is how many inches?
1 inch =2.54 cm exactly.
11 cm =11/2,54 =4.33 cm
Mar 29, 2014 | Office Equipment & Supplies
Water leaking from bottom Sears Model
Most likely the water pump go to this web sitte to get the parts price and break down on the macine for repairing. you need to raise the washer to be able to see exactly where it's commming from I use a 2x4 to or 2x6 to raise the front of the waser up far enoght to see where the water is comming from and use a flash light. be sure to stay out of the water while it is running or unplug it altogether if it leaks plugged in or not, then use the flashlight to find the leak. be arare it could be the hose or the tub seal as well and that water travels. Use you hand to feel excatly where the wter is comming from. the web site is http://www.applinacepros.com. If you need more help just post to this answer to get more help.
Nov 16, 2009 | Washing Machines
My Braun BP meter (model 6071) will not hold pressure in the cuff. It appears to be leaking. Can I replace this ? Where are the parts able to be sourced from? I live in Australia but bought this item from...
In my experience as a nurse the major points of leakage are at the junctures near where end of tubing is. The way I have fixed both my own and my hospitals cuffs is to identify where the leak is occuring and if it is in the tubing disconnect at that point and use scissors to cut off the leaky part of tubing at the point of tubing leak and reconnect careful to take only enough off to sever leaky part. If the leakage is in a valve I cannot help you but the vast majority of leaks are in the rubber tubing
Jun 20, 2009 | Braun Health & Beauty
Ingersoll rand compressor oil leak (Model DD2T2, 4.5 Gal.)
The brass fitting that goes into my DD2T2 seems to have a hole in it and it looks impossible to remove without ruining a major gasket due to the close tolerance in replacing the fitting. Am I missing something?
Mar 09, 2009 | Ingersoll Rand DD2T2 T Win Stack Single...
Ford Ranger 2.5 TD XLT, 2005 model has started to leak a little oil. Cant work out where its coming from. Not a major amount of oil, but its definatley oil. Any ideas?
see if your rocker cover is is sealed right check to see if your oil filyer is sealed both could be leaking or 1 of them could be leaking
Nov 07, 2008 | Ford Ranger Cars & Trucks
Garden Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
