Question about Whirlpool AWOE8748 Front Load Washer
I have a whirlpool AWO 3761 and it says " clean
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem!
BTW manual-
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 12, 2011
My whirlpool washing m/c 1400rpm awo/r 5406 will not complete the wash cycle it washes until it gets to spln and drain then the service light comes on (spanner)washer stops working but water still flo
locate the dranage water pump, screw it ou nd clean or check on the filter cuup,,always situated next to the water pump below,,u can trace the pump along with the outlet
drainage tube
Jan 26, 2015 | Whirlpool Washing Machines
Whirlpool front loader - 6th sense AWO 3561. The machine is stopping on the rinse part of the cycle and E09 is displayed in the "remaining time" display. The "water tap closed"and "clean pump" lights were...
please consult the user guide from the manufactures website its usually free to download and go to the problem shooting section for a possible answerer eric
Dec 19, 2017 | Washing Machines
I have a awo 3761/5/s model and it keeps coming up on the display fh and the lights flash what does this mean
Unfortunately there are so many abriviations that one cant keep up.(not standardised). Best thing to do is do a manual check. Switch water off and check the filter. Clean it. Next, do a check and confirm that the drain pump is free of obstruction and free to turn.(loose). Get motor to spin by selecting spin and see if it does. If all those checks work out, it should function.
Jun 05, 2010 | Whirlpool Washing Machines
After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 02, 2009 | Washing Machines
Whirlpool awo 3761/5/s
have you checked that there is not a blockage in the outlet pipe or that it is not kinked?sometimes if the pipe is lying to low (ie creating a u-bend) this can prevent water getting in & out & so the machine interprets it as either taps off or the pump needs cleaned (this has happened to me numerous times :) )
Nov 24, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool AWO 3761/S
Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool AWOE8748 Front Load Washer Logo
267 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
