I installed Ubuntu 10.10 on Acer aspire 7520G. Everything works good, however some of the keys, like the numeric side keyboard does not work and I do not know how to make it work.
    Scholar:
  • 72 Answers
Try
Crtl+Shift+NumLock
Or
Go to :
1) System
2) Preferences
3) Keyboard
4) Click Mouse Keys tab
4) Uncheck: Allow to control pointer using the keyboard
Posted on Mar 12, 2011
  • gabor_me Mar 12, 2011
    I tried what you say, and it does not work. The mouse control with keyboard is unchecked and ctrl shift numlock does not work. there are also some other keys that are dead. i have an euro and a dollar sign next to the arrow keys and they do not work either. can anyone help?
    thanks.
    Gabor
Num keyboard not seen with NEC-versa-M370 running ubuntu 10.04
I have installed the pack numlockx, activated it with the procedure described on ubuntu.org. Then by making CTRL SHIFT VerrNum (ubuntu.org procedure), the numeric keypad that had been inefective for one year began to work again...
Dec 08, 2012 | NEC Versa Computers & Internet
What's your problem?acer aspire 7720 numeric side doesn't work after change MB
Is your keyboard a PS/2 or a USB one ? if its a PS/2 (the cylindric connector) find a PS/2 to USB converter and plug it into a USB port (the flat rectangle connector)
Feb 02, 2012 | Acer Aspire 7720 Notebook
Hi i have got a new keyboard and wish to change it on acer 7520
taken from http://www.batterycentury.com/acer-aspire-7520g-502g25mi-keyboard-p-152819.html
Acer Aspire 7520G-502G25Mi Keyboard Repair and ReplacementAre you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick Acer Aspire 7520G-502G25Mi Keyboard repair tutorial with step-by-step instructions. Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the Acer Aspire 7520G-502G25Mi Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Acer Aspire 7520G-502G25Mi Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Acer laptop keyboard.
Final step: To insert the new Acer Aspire 7520G-502G25Mi Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Acer Aspire 7520G-502G25Mi Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
May 16, 2011 | Computers & Internet
My 10-numberic keyboard on my acer aspire 5742Z-4200 has stop working, when I press the number they do not work. How can I fix this problem?
NumLk must be on for the numeric keyboard to input the numbers on the keys otherwise the keys default to the functions marked at the lower part of the keys. To turn on NumLk, just press the NumLk key on the top row of keys above the numeric keyboard.
Mar 26, 2011 | Acer Aspire 5742Z-4200 Notebook
My Acer Aspire 7520G gives, most of the time, no sound. Problem with the Acer Aspire 7520G 17.0" Laptop Acer Aspire 7520G gives, most of the time, no sound or audio device in windows 7. 2 days ago I...
Try installing the latest audio driver.
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Feb 18, 2011 | Acer Aspire 7520-5185 Laptop
Keyboard Replacement Instructions for Acer Aspire 7520g
if ur key board is guranty period than ur keyboard is replacement by service center oterwise warrnty period only repaired by service center.thank u
Jun 03, 2009 | Computers & Internet
Acer Aspire 7520 numeric keypad problem
Try pressing the numlock key in the upper right part of your keyboard. Chances are it's turned off and therefore the numeric keypad will not work.
Feb 05, 2009 | Acer Aspire 5500 5570-2609 Laptop
Logitech MX 3200 wireless keyboard Numeric (right side) keypad does not work.
maybe it is full of dust on those buttons. Try cleaning it with a duster of mini-brush because it interrupts the function.
Jan 30, 2008 | Logitech MX3000 USB PS/2 Wireless...
Acer Aspire 3000 Series Numerical Keyboard/Function Key Problem
if using XP go to my computer, right click>properties>hardware tab>device manager>look down list for keyboard, click '+' sign and highlight your keyboard and right click and select uninstall. Restart the notebook and the keyboard will be installed automatically along with the drivers and should set it back to default.
May 21, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
