Question about Electrolux Icon E23CS78ESS Designer Series 36" Side By Side Refrigerator w/ PureAdvantage¿ Filtratio...
Digital display flashing on fridge/freezer electrolux erl6297kk1 blue letters flashing f1/ff
5 Suggested Answers
SOURCE: Electrolux Fridge 2 Door, Electronic Panel Problem
there s three plastic boxes the size of three inches long and two inches high there,s a leak there
Posted on Apr 13, 2009
SOURCE: digital temperature display are flashing for Electrolux Refigerat
Khouripablo
Did you find one solution for it problem? I have the it problem in the some refrigerator. Please send me one good answer.
berghi@windstream.net
Posted on Jan 06, 2010
taran_2005
  • 10515 Answers
SOURCE: my electrolux side by side
This is a really bad error on this model.
EF error means there is a problem with the control board. You should unplug the unit for 30 seconds and plug it back in. If this does not clear the problem you could try unplugging the unit for 12 hours in order to clear the internal memory and battery (this has worked for me a few times) If this fails to clear the problem you will need to replace the control board
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 27, 2010
  • 552 Answers
SOURCE: Electrolux Icon side-by-side E23CS75DSS - repair
Sounds like you have a evaporator fan motor. That is what the error code you have indicates, the fan blade could be stalled to.
I work on these units every day and know them very well, I can walk you through any repair on this refrigerator.
http://www.appliancerepairlesson.com/
Posted on Mar 01, 2011
Samsung fridge freezer
Sounds like it has a brain cramp. Try unplugging the power cord, wait a few minutes and plug it back in. Also look for resets near where the power cord comes into the unit.
Feb 18, 2014 | Refrigerators
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
Fridge freezer
HI jACQUELINE.well i reckon the fridges r a bit temperaMENTAL.:).Before u do anything well u can check weather u have ice build up on the rear panel inside freezer compartment.either way i would first turn it off for 24 to 48 hours.then remove bottom plinth panel (bellow the door).thoroughly clean condenser coils right to the end.then try u could get lucky.if it doesnt work then the problem could b inside the panel.def/heater,fan motor,t/stat,or the board.good luck Ali
Aug 24, 2012 | Refrigerators
Fridge freezer alarm going & turning from blue to red
Possible there is some issues with the control panel and must be taken out to be confirmed. It can also be some loose connection on the connectors or the lamp holders.
Also check the wiring to the board.
Jun 28, 2012 | Zanussi & Electrolux Fridge Freezer Handle...
Electrolux Icon side-by-side E23CS75DSS - repair man replaced the defrost thermostat and now the digital temp display flashes. The freezer temp display flashes "E" and the fridge display flashes...
Mar 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Jul 10, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Apr 04, 2009 | Electrolux Refrigerators
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Electrolux Icon E23CS78ESS Designer Series 36" Side By Side Refrigerator w/ PureAdvantage¿ Filtratio... Logo
81 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
