Question about Samsung CLP-315W Laser Color Printer
I have a CLX-3185FW connected (WiFi) to my network. Printing / scanning is working fine but when the printer goes into offline mode (power save), the printer becomes invisibleto the network and I cannot wake-up the printer again. Only way to wake-up is to switch off the printer and switch it on again. When I connect the printer with a network cable it simply wakes-up through the network cable.
5 Suggested Answers
SOURCE: How to turn off wireless
Posted on Mar 12, 2011
SOURCE: How can I turn a
CLX 3185FW wireless works and prints, but if printer is on it disrupts the internet connection of 1 of the attached computers. Turn the printer off and internet is fine. Two other computers work fine. Connected to a Linksys router. Win7 64. Thoughts?
Posted on Mar 14, 2011
  • 111 Answers
SOURCE: Samsung CLX 3185FW WiFi Printing
it means that your printer is connected via WiFi but the data can not be transferd. Could be the distance to the printer is to far.
Posted on May 16, 2011
hattinghbr
  • 214 Answers
SOURCE: Samsung clx-3175fn printer is showing
first you can feel if the fuser get warm at the back of the unit. if not replace the fuser unit.
Posted on Oct 14, 2011
SAMSUNG CLX-3185FW SPL-C ERROR - INCOMPLETE SESSION BY TIME OUT
try printing with the right driver and make sure if ur computer is 32 bit or 64 bit...
Mar 30, 2013 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
How to resert the counter of the fuser of samsung clx 3185
Do it in Tech mode
Menu # 1 9 3 4 Menu
Navigate through the menus to find the Counters menu, fuser is in there from memory (I reset imaging unit only recently on CLX3185FN but saw fuser in the menu as another option)
Or you can wipe EVERYTHING with "clear all mem" option
Password 1934 worked fine for me
May 03, 2012 | Samsung CLX3185 Printer
Bought a Samsung CLX-3185FW to be able to print wireless from my macbook pro with snow leopard OS X 10.6. Software seemed to load ok, but each time I try to print, the mac is saying the printer is of
it really works ! you just simply have to update the printer drivers ( if it is connected to network and supports wireless printing) . I have done so in my office and everything works just fine. i
Jan 21, 2012 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Samsung clx-3180 printer is showing printer offline and will not print from pc.
CHECK
Printer is connected and power ON
In panel contro
go to Printers
choose Samsung Clx rigth click
unmark the check Use printer offline
Try printing a test page
rigth click Properties
click on
Print test page
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Hello - Samsung CLX-3185FW printer - I have loaded software into my mac and each time I print it tells me that the printer is offline. Can you please help? Claude
Download and install Printer Driver (Mac OS) -->start download
Scan Driver->start download
Smart Panel Driver ->start download
You could try a different USB port on the MacBook and a different USB cable
May 22, 2011 | Office Equipment & Supplies
Samsung CLX 3185FW WiFi Printing from MacBook Pro.WPS connected, Unable to send trailing nul to printer.broken pipe. What does this mean???
May 15, 2011 | Samsung Office Equipment & Supplies
I have a new samsung printer all in one clx 3180 fn, i installed her in my pc's through the installation cd and made the printing test over the network (wlan) everyting was ok. then i tried to scan a...
you need to delet the printer software from your computer and install it again, then it should work, if not download the driver's from samsung download page.
Apr 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
How to turn off wireless of samsung color laser printer clx-3185FW
The manual doesn't specifically state this but it appears that if the printer is connected to a wired LAN connection the wireless function will be disabled if the printer is set up in infrastructure mode. When I tried this the 'wireless' light turned off and I wasn't able to find the printer's WiFi SSID using a nearby netbook. If your goal, like mine, was to disable the printer's WiFi from transmitting to reduce extra WiFi noise then this seems to work. One of the wireless troubleshooting tips in the manual states to disconnect the wired connection before attempting to set up a wireless connection so it appears the two can't be used simultaneously. It seems odd that there's no specific "off" setting for wireless though. The printer will provide a WiFi connection when also connected to a wired LAN port if it is set up as part of an ad-hoc wireless network so make sure you set it to 'infrastructure' mode to disable WiFi.
Feb 11, 2011 | Samsung CLP-315W Laser Color Printer
How can I turn a CLX-3185FN into a CLX-3185FW?
Buy a Netgear WNCE 2100 which has one wired ethernet port connected internally to a wifi radio which is a 2.4GHz transceiver with WPA security. Fully compatible with most routers from D-Link, Netgear, Buffalo, etc. The samsung printer has a USB port to which you can connect and power the WNCE2100. This product is called by two different names. Sometimes it is called a Universal Ethernet Adaptor and others it is called a Network Bridge--which is more accurate. The Netgear product is b/g/n compatible. Try to place it not more than one room away from the router because the signal strength drops very fast if it is more than one wall and or 40feet from the wireless router.
Jan 03, 2011 | Samsung CLX-3175FW Multifunction Laser...
Samsung CLP-315W Laser Color Printer Logo
794 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
