Question about Breville VHB012 2Speed Handheld Blender
Breville model vhb012 attachment to the bowl connection has sheared am I able to get a replacement, the bowl is ok
The chopping mechanism, which should turn freely, is "frozen" & won't turn. not even manually.
I'm assuming that this isn't happening on an model in which the bowl can be detached - otherwise the plastic bushing has melted and glued the shaft to the base of the mechanism - it will have to be replaced. You can find one on the Breville site
http://www.brevilleusa.com/blending.html
select yours and you will find it in the Parts &Accessories tab.
The mixer has an plastic bushing on the shaft of the chopping mechanism that is there to connect it to the shaft of the motor. If that bushing or the bearing of the shaft got damaged in any way the entire mechanism will lock out.
To find out what exactly happened you will need to dismantle the mixer - take out the 4 screws on the bottom, unclip the power wire, remove the supports of the motor and pull it out for inspection. Parts from older models can be obtained only from a dealer, you will have to contact one and order it .
Jul 30, 2011 | Breville Blenders
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
Breville blender won't turn on. The on light is flashing red instead of solid blue. Worked fine a few days ago.
FIXED IT - It's the screws on the bottom of the jar assembly, where the blades are attached. There are 4 Torx screws - star-shaped - and when these come loose over time the Blender will start to operate only sometimes. Eventually it will be never.
Tighten these four screws and everything will be fine!
Oct 02, 2010 | Breville BBL600XL. 5-Speed Blender
Need new chopper bowl for the immersion blender by Wolfgang Puck
Replacement parts for Wolfgang Puck Immersion Blenders are available here:
http://www.wpcookware.com/categories.asp?cat=26
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Sorry someone has not responded sooner but just discovered this site.
May 02, 2010 | Wolfgang Puck Immersion Blender
Grease build up around blade and where it attaches to base
Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
Mar 09, 2010 | Breville BBL600XL. 5-Speed Blender
The screw that holds the mixing blade in place sheared off. Is there a way to replace this screw?
Try bonding the sheared portions with Araldite. Once it is set try slowly to unscrew. OR if you can make a little nich in the embeded portion so that tip of screw driver can fix it. Then it should be easy to unscrew the sheared portion. Otherwise no other alternative but to replace the attachment.
Jan 23, 2010 | Kenmore Blender Single-Speed Blender
Breville hand blender doesn't blend continuously
I have the same problem. Mine used to work, has only seen light use, and now it runs for about 1 second before it shuts off. Expensive POS. There don't seem to be any solutions either.
Nov 18, 2008 | Breville Cordless Hand Blender - Silver
Attaching top container to bottom tub.
Place food processor attachment on base
Put work bowl on gear collar with left slot just to the left of the tab on left side, slide until tabs click
Place work bowl lid on top of workbowl with tabs slightly to left of work bowl handle - slide into place until it clicks
Nov 13, 2008 | Cuisinart BFP-703 Blender
Instructions breville party time ice cream maker
too late now, it has thawed. Throw it out or give it to the cat.
Apr 20, 2008 | Blenders
Breville VHB012 2Speed Handheld Blender Logo
35 people viewed this question
Top Breville Blenders Experts
Mike
Craig Butler
Craig Butler
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
