Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon MP Pixma 500 - Not working - error code 6A00?
  • 240 Answers
SOURCE: Showing printer error 6A00
I just copy this solution for you to this link:
the solution is posted by BAB..
they have the same problem as you ..then this solution solve it..^^
http://www.fixyourownprinter.com/forums/inkjet/39177
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Posted on May 19, 2009
komguy
  • 2306 Answers
SOURCE: canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Posted on Jul 24, 2009
komguy
  • 2306 Answers
SOURCE: Error code 6A00 on Canon Pixma Mp600
That error means the purge or cleaning station on the right where the printhead parks is jammed and can't move properly. If there is no paper stuck in there, you need a new purge assembly. about $30.00
Posted on Oct 20, 2009
Testimonial: "Wonderful response will remember you John Chelmsford England"
Semi-Driver
  • 434 Answers
SOURCE: canon mp 600 error code 6A00
When the printer is not functioning properly you may need to reset it:
1) Press and hold <On/Off> for one second. Display will go blank. (If this does not happen, unplug the printer).
2) Wait approx. 10 seconds
3) Plug in the device - Press <On/Off> if necessary to power on the printer
4) Wait until the device has finished its startup routine
If the problem still persists, your MP600 may need servicing by a qualified technician.
Posted on Dec 27, 2009
trisha8765
  • 120 Answers
SOURCE: Any help with a Canon Pixma MP 250 P2 Error Code?
I found you a site where you can download the latest drivers to install at the link below Good Luck
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=All-in-One Printers&series=All-in-One Printers&model=PIXMA MP250&menu=Download
Hello! I am using a printer PIXMA MP 500. When I am trying to print it's not possible and on the screen there is a message:Service error 6A00, with suggestion to cancel printing and turn the printer off...
Hi you can try
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All the Best:Pineworks
Jan 11, 2010 | Canon Pixma MP500 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Code 6A00 -
6A00 means that the purge assembly, thats the cleaning unit where the printhead parks when off on the right, is jammed and cannot move.Look for paper or foreign material stopping it from moving. Sometimes the squeegee unit needs to be pushed back if the pads get stuck under it.
Jun 24, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Error 6a00 canon pixma 500
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Display Shows Error 6A00 and it Doesnt Work ahead
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Jun 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp 950 has a error code 6A00
There is a problem with the carriage lift mechanism.
Probale causes
1.PR Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Only your local Canon Dealer will know
Mar 12, 2009 | Canon Pixma MP950 All-In-One InkJet...
My Printer says error code 6A00 What do i do?
Try this especially if the printer had not been used for some time.
Switch it off, open the lid and manually (GENTLY!)slide the cartridge-tray to the left. Then you can see if a piece of paper or ink stucks it. Gently degunk the base pad with a little isopropyl alcohol on a Q-tip and ease the mechanism back.
Dec 01, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP 810
Try moving the cartridge unit back and forth a few times, this usually works.
Jul 15, 2008 | Canon PIXMA MP810 All-In-One InkJet...
MY Canon Pixma MP 500 Printer won't Print.
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 15, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
old marine
old marine
