Question about LG GSA-H55N DVD-RAM Burner
Hi,My dvd writer can no-longer read/burn cds and dvds.It usually fails at around 17% and ejects! costs me alot of cds that are wasted..PLIZ HELP.THANK YOU..
    Guru:
  • 1,705 Answers
Open the draw and give it a blast with compressed air from an aerosol can or play a CD lens cleaning disk, if that doesn't work, don't try too hard, get a second hand replacement from ebay or any second hand shop you have near you.
Posted on Mar 12, 2011
Error 0a-0224-0000
Dear Vincent,
The 0A-0224-0000 is a "File Copy Failed" error. It means that either the computer was not able to read from the CD/DVD or it finished reading from one CD/DVD and was expecting to read data from the next one (when you have two or more recovery CDs/DVDs). If you have more than one recovery CD/DVD, as soon as you see the CD/DVD reader LED (light) stop flashing, eject the CD and insert the next one in the sequence, doing so till all recovery CDs/DVDs have been read.
If you cannot eject the DVDs by pressing the eject button (some DVD writers only allow you to eject the disc after finishing the whole operation) you will have to straighten up a paper clip and insert it in the small hole close to the eject button to force it open and change the CD or DVD (do a Google search for "how to open a CD or DVD drive with a paperclip, in order to better understand how to do it)".
Hope this helps!
Oct 31, 2013 | Toshiba Computers & Internet
Can i burn the mini cd's/dvd's in my inspiron 1525?
Yes you can, your Notebook has a Dvd Writer with it, mini or normal dvds/cds will burn well without any problem if the Cd/Dvd Drive has no issues reading/writing Cds/Dvds.
Good luck.
Thanks for using FixYa.
Sep 22, 2010 | Dell Inspiron 1525 Notebook
TDK Life on Record 1-16x speed DVD-R keeps failing when writing. I have burned about 25 dvds from this TDK pack, and all burn normally right up to near the end when my Nero burner software notifies "Burn...
You could try diferent burning software.it may even be a hardware fault the dvdr drive.cds and dvds burn and read data from inside to outer edge.as the laser moves out twards edge the speed of disc changes to compensate for larger distance travelled so a worn drive can sometimes start to show this fault.also sometimes only play half a film or stop at track 10 on cd
Apr 19, 2017 | Computers & Internet
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
My CD/DVD rom drives have quit operating . What can I do to restore them ?
A friend of mine had the same problem, we couldn't get his dvd writer to work. It would read the CD but it couldn't burn dvds/cds. We had to buy a new DVD writer. You can get a really good one for around $60. An asus one is good. Check to make sure your dvd writer is plugged in usually by IDE cable and power cable. Newer ones might have SATA. Get a new one and unmount the old one and place the new one where the old one was. You'll need an antistatic wrist strap to ground yourself.
Aug 16, 2009 | Dell XPS 600 PC Desktop
My writemaster sh-w162 will reconise cds but not dvds can you help, im using library computer .it will copy or burn cds not dvds
actually the problem of your writemaster is the speedometer or what we call Laser Eye. This Laser Eye is damage but not totally can read only CDs but not DVDs, you can no longer burn a DVDs on it, i experience to that, only CDs can read and write on it. This time you buy a new DVD Writer to replace on it, or if warranty you can send it back to the Store you buy. I tell you it is still not working.. Just buy a new one. Good Luck!
Jun 25, 2009 | Computers & Internet
LG dvd writer stops at 1%
if you have an antivirus then uninstall it, then check
or do the fresh installation of OS
Nov 20, 2008 | LG GCE 8481B CD-RW Burner
DVD NOT READ
if you are good at opening then open the combo drive and clean the lens once by using some lens cleaner solution and then refit it it should work ...
if you still persist the problem then think that the life of the combo drive is getting down and the time to purchase new one is getting nearer ..
after some days your combo drive will fail to read the cds but it will read occasionally for some days after that it will not read anything that s because the lens is becoming weaker ...
at the cost of replacing the lens you can purchase the new dvd writer ...
but also try cleaning the lens with some lens cleaner solution after that it may work for some days ..
the only problem with the combo drive is the lens will be weaker than the normal dvd writer or cd writer so after some days of usage it fails to detect dvds followed by it fails in detecting of cds too ...
thank you
rate my solution
Sep 11, 2008 | Computers & Internet
DVD burning problem
if you have tried different dvd-r and dvd-rw discs, unfortunately it's a sign that your writer is failing to read the discs correctly, this normally happens when the writer is about to give up, although it may still write and read cd's but not dvd's
Sep 01, 2007 | Computers & Internet
LG GSA-H55N DVD-RAM Burner Logo
81 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
