Question about Samsung WF328AA Front Load Washer
My daughter is living in Russia and has a compact Samsung washing machine. She can't work out where to put the fabric softener. When she put it in the tray she thought was the right one it spilled out on to the floor. Can you help please?
    Brigadier General:
  • 6,277 Answers
Two answers, both pre-typed by me, the second is possibly the reason for the spillage ;-0)
1) Which tray.
A quick way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
2) Leaking detergent dispenser
This is a common problem with many machines.
I suspect that it is the conditioner/softener tray which is causing water to overflow from the dispenser drawer so it needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck to your daughter,
John C
Posted on Mar 12, 2011
The fabric softener compartment in is full of water. I need to empty this manually prior to each wash . Many, many thanks. Judy
The fabric softener dispenser has to be purged between wash cycles to prevent residue from clogging it. What you are observing is normal operation.
Jun 25, 2016 | Washing Machines
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Water in slot for fabric softener wont drain. Always water in there. Lameez SA Jan2014
Remove the dispenser draw and wash it all out. The most likely cause is that fabric softener has congealed and blocked the dispenser. I hate what softeners do to machines with a vengeance. I would never put any fabric softener anywhere near my machine ever. They cause many problems that are not easily remedied.
Regards
John
Jan 30, 2014 | Bosch Washing Machines
Fabric softener compartment
You will need to clear the line from the fabric dispenser to the tub.
Oct 15, 2012 | Kenmore HE2 Plus Front Load Washer
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Bits of black in the wash other wise works fine
I had that happen with a Samsung top loader last year. It was easily cured by reducing the amount of fabric softener that I used. It's so easy just to fill the fabric softener dispenser to the brim, instead of just putting one capful in the dispenser. That was the advice that the Samsung company gave me and it worked fine. I had to remove the inner cylinder first because the black bits were stuck to the outside of the inner cylinder and needed brushing off........ but that was an easy job. Good luck.
Oct 21, 2011 | Hoover HTC243 Top Load Washer
Samsung WF328AAW front loading washer, about 3 years old. Having persistent scum build up on the multiple water inlet holes that flush the fabric softener from the dispenser into the wash. Have tried...
I put my fabric conditioner in drum in one of those plastic tubs u get with persil liquid. I was fed up cleaning the drawer with steamer and toothbrush. Maybe someone has some more technical advise but find this works for me
Regards
May 09, 2017 | Samsung WF328AAW Front Load Washer
How to use fabric softener
On this machine the compartment is built to hold your softener until it is time to be dispensed. So put in your softener (and bleach if you are using it) at the beginning of the load when you are adding your detergent. The washer will flush the fabric softener cup during the rinse fill to make sure it comes in at the right time for you.
Hope this answers your question!
Jul 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Is it ok to use fabric softener sheets with the
Use the liquid. The sheets will clog up any exhaust pipe or other parts in the dryer. If you live where you vent through the roof, definitely don't use the fabric sheets.
Jun 24, 2009 | Samsung Dryers
Washing machine does not take fabric softner
Obstruction, please take the whole soap compartment out and do better job with old tooth brush on the compartment in the sink and the machine itself. Should do it unless you live in very cold environment.
Apr 14, 2009 | AEG Lavamat 72640 Front Load Washer
Samsung WF328AA Front Load Washer Logo
119 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
