Question about Samsung SW62ASP Top Load Washer
My Samsung AG Plus Nano technology washing machine goes through the washing cycle, but does not stop adding water when going into rinse cycle, it then starts to overflow?
  • 351 Answers
SOURCE: GE WASHING MACHINE GWSR3090W
check the inlet valve when it flood unplug power the water should stop if it doesnt its the valve.if it does it could be the pressure switch.hope this helps.
Posted on Mar 09, 2008
SOURCE: Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Posted on Mar 21, 2009
SOURCE: Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Posted on Apr 22, 2008
Illeagle
  • 525 Answers
SOURCE: Washing Machine won't stop filling up
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
Posted on May 24, 2008
  • 1294 Answers
SOURCE: Maytag Neptune mah7500aww adding water to wash cycle problem
Your inlet valve at behind top of machine is defective; or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Pl rate if helped.............
Posted on Jun 13, 2008
My Elba washing machine, when reaches the rinse cycle, water is very loud, never before, but it never stops adding water. Water is draining fine but water does not stop to cycle to rinse.
The water inlet solenoid valve is being held open. Take off the hose and look in the opening to see if you can find anything. Otherwise replace that solenoid valve.
Sep 02, 2016 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Samsung SW62ASP Top Load Washer Logo
178 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
