Question about Graco Bassinet 3-in-1 3011 Crib
I just bought a graco freeport bed and the side rail had no screw holes in it to connect to the bed how do i get a new rail with screws and send the old one in for repair
We just opened our crib, have the same problem. What did you end up doing?
Posted on Sep 04, 2011
The bolts got lost when we moved. Where can i get some replacement screws?
Graco might be able to supply the hardware if you inquire but bear in mind that use of the wrong hardware presents a safety issue.
May 10, 2016 | Graco Freeport Classic 4-in-1 Convertible...
Does anyone know where i can find the instruction manual for my crib model #343-8420-0018?
Found this :
Can you help with this Cribs Cradles Bassinets question posted on FixYa
  1. Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
  2. Lower the mattress to the lowest setting.
  3. Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
  4. You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
If this doesn't help you can try contacting the store you bought it from.
Apr 11, 2014 | JCPenney All-in-One Nursery Crib
Mislaid assembly instructions trying to get a email copy if possible for "Adam Cot Bed"
Here you go: http://www.babystyle.co.uk/pdf/CalgaryCotbed_AI.pdf
May 24, 2011 | Toys
I just got a used graco metal baby bed and can't figure out how to install the side rail that moves up and down. Please help
These are complictaed and not very safe. Most of the older Graco cribs have been recalled.
In my experience, the metal dropside guides can come loose. This may allow a child to slide down thru the edge of the mattress and the metal dropside. I would not use the crib. It is truley unsafe.
If you insist on using it, drill a hole thru the headboard and footboard and drive a screw thru
into the soft plastic guides on the dropside to make it a stationary side. Please, for your childs sake,
get a new crib. You only get one chance with a child. It's not worth it.
Mar 06, 2011 | Graco 9445DOH Crib
I lost my manual, I need to know how to transform the crib into a toddler bed
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
mkd123_2.jpgGraco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
Jan 23, 2011 | Simplicity for Children 4-in-1 Convertible...
2002 Graco crib instructions . i bought a used 2002 crib and I need to know how to put it together.
ok first thing first ,  some graco cribs and other products from 2002 -2010 are being recalled , so what crib model do you have? second , putting together a crib is very easy , . First , take the head board and stand it up , next find the side railings and one by one put the screw thru the rail and into the headboard , hold it in place untill it is where it needs to be , then put the second railing on , the screws should go thru the rail and into the headboard with the headboard in back of the rails, after the rails are secured then hold the foot board in place untill the screws are fastened into the rails as well , after you do this , then go around and make sure all the screws are tightned, then take the mattress spring and place it inside the setup rails and screw it unto the places alotted for the screws , then after this , place the matress inside and your done....if this doesnt help , please email me at konmon52@aim.com and tell me which model it is
Nov 19, 2010 | Graco Baby Gear
Graco 3-in-1 crib instructions
Check this CPSC link.
Most if not all of the simplicity brand cribs have been recalled reguardless of whether they had wood or metal mattress supports.
There were 2 different recalls on the wood version but both were recalled for the drop-side issues.
This link specifically includes the Aspen 3 in 1 cribs and model #: 8740
We took ours to our local walmart last summer (we purchased it in a different state almost 8 years ago). I brought to cpsc report with me. They had not issue with the recalled information we has matching it to our crib. It did take the clerk a bit to find our crib in their system because it was older, but once she did we recieved a full refund, without a receipt.
As far as changing them to a toddler bed. When we converted ours to a toddler bed we simply removed the drop-side from the crib. The drop-side parts can be unscrewed from the side rails. Then we screwed the toddler rails to the bottom of the crib. Ours had screw holds for the toddler rails on the mattress support. If you do not have the holes for it, then you may have put the mattress support on backwards ie with the side that has the holes for the toddler bed rails on the backside of the crib.
Dec 04, 2009 | Graco Apsen 3-in-1 8740 Crib
Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Jul 12, 2009 | Bassett Cottage 3-in-1 Crib
Converting bed..need instructions
Most if not all of the simplicity brand drop-side cribs have been recalled, including the Graco 8740.
Here is the CPSP link regarding this crib:
http://www.cpsc.gov/CPSCPUB/PREREL/prhtml09/09260list.html
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07307.html
According to the CPSP information the company appears to be out of business to some degree and are not providing repair kits.
If you know where you purchased the crib, check to see what their policy is regarding recalled baby products.
We had purchased ours at walmart almost 8 years ago and were able to return it to another store in a different state for a full refund last summer. They did not need a reciept received, they just needed the manufacturer label on the part that the mattress lies on.
Because ours was older, the customer service clerk did have to work hard to find the crib in their system, but once she did, it was not problem at all.
Toddler conversion on at least some of the cribs is simply to remove the front dropside from the crib (you may want or need to unscrew the dropside tracks to remove the actual side) Then screw the toddler rails to the front side of the crib. There should be pre-drilled holes for the toddler rails, if there are not then you may have the mattress support on backwards.
Mar 12, 2009 | Graco Apsen 3-in-1 8740 Crib
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Apr 26, 2008 | JCPenney All-in-One Nursery Crib
Graco Bassinet 3-in-1 3011 Crib Logo
222 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
