Question about Bosch HBN 7052 GB Stainless Steel Electric Double Oven
I have a Bosch HBN7053GB /05 oven which worked fine apart from the bottom oven does not heat up, the light and fan are both working just no heat. I have replaced the element but still no heat, so now im not sure if this is a faulty element or a probem with the temperature control. Any help or advice would be really appreciated? Thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
You changed the element does everything else work fine, stovetop elements,broiler etc.if so check your wiring going to the new element and to the switch if they are fine it may just be the temp/control switch
Posted on Mar 12, 2011
Bosch HBM13B2.1B main oven not working
The bottom oven will not operate if you have not set the time. Check this first. repost if you need further assistance
Mar 31, 2013 | Bosch Ovens
Tip
Common heating faults with Bosch HBL 5056 double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 5056 Electric Double Oven
Tip
Common heating faults with Bosch HBL3420UC Electric single oven
on Jan 19, 2010 | Bosch HBL3420UC Electric Single Oven
Bottom oven not working only fan & light works - top oven works fine
The ovens have separate heatin elements. Sounds like your bottom oven element needs replacing
Jun 30, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Bosch double oven, fan and light work but won't heat.
my lower oven wont heat on my HBN 70 got light and fan but no heat
Oct 18, 2009 | Bosch Ovens
Tip
Common heating faults with Bosch HBL 5032 single oven
on Jan 19, 2010 | Bosch HBL 5032 Electric Single Oven
Tip
Common heating faults with Bosch HBN 430560B / 430520B single oven
on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
Hbn7052gb/05
If you have a BOSCH electric Cooker or Fan Oven which isnot heating it could be one of the following problems.
1, If the fan motor in the back of the oven is goinground and the temperature light is on (normally little red light), but there isno heat then you will probably need a new oven element, these are generallyvery easy to fit and readily available from our website these can be testedwith a electric meter.
To gain access to the BOSCH element you will have to remove the back platefrom inside the oven. Once removed you will see the fan and element,if you look closely at the element you will probably see a small holeburnt in it where it has blown. Sometimes however there is no evidence of afault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your BOSCH fan oven is getting warm but takes avery long time to cook or is burning the food more on one side than the other,then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into theoven then you need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your BOSCH oven thermostat
4, A quite commonand easily overlooked answer is if your BOSCH oven is not working at all ie: no heatand no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Jul 30, 2009 | Bosch HBL 5032 Electric Single Oven
Fan oven not heating
its the element not the stat
Mar 10, 2009 | Bosch Ovens
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
367 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
