Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubichi WT-46805 Convergence IC's I was wondering where i might find them to replace on the circuit board? I cannot seem to adjust convergence on the menu option. So I thought I might replace the IC's. Any help would be much appreciated !! Jerry
  • Bosjerry Aug 05, 2008
    My model uses STK392-040 not STK392-570.
    also there is a convergence board in front that controls both audio and convergence.
    My question was what would be the first thin to try to maybe solve the convergence problem, also no audio?
    Hello there,
    I have a WT-46805 Platinum Chassis V-16
    I was told to replace the IC's But noticed a Convergence-Gene in front of the IC's.
    I also have no audio. So I was wondering what you might suggest.
    The manual says you can adjust from the menu, under convergence, but i found the buttons do not work to adjust the lines.
    So here I am........
    Also would you know where I can get this card or IC's fairly reasonable?
    Thanks
  • Mitsubishi Master
  • 8,617 Answers
Your model uses two STK392-570 Convergence ICs, you can get replacement ICs at the following link and they provide free instalation instructions with pictures and free online tech support to help incase you need additional help. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Aug 01, 2008
How do I replace the fuses on a WT-46807 that protect the convergence circuit?
There are no fuses going to the convergence board, the converegnce IC needs replaced.
Aug 08, 2011 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT 46805 ~ Picture gone..... :0(
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I think that you have two that are on the board in the center of the set. They are secured to a very large aluminum heat sink.
There are two ways to repair intermittent connections on the convergence IC’s. I usually remove the board with the convergence IC’s on them and then and solder the connections. The other method is to tilt the circuit board and solder them while still installed in the chassis.
If you remove the board and repair the connections, be careful to remember which connections need to be made when you replace the board. Mitsubishi uses a lettering system, so it should be easy.
If the problem remains after you have made the repair, it is possible that the pins on the IC’s have become loose. In this case the IC’s need to be replaced. I have seen this on several occasions.
If you choose to repair the set yourself, be very careful of the high voltage that can be stored in the capacitors, and CRT’s. This voltage can be as high as 30,000 volts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 29, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Convergence on mitsubishi WT-46805
Mitsubishi is famous for this. You are going to have to resolder the convergence ICs. Very simple repair if you are just a little tech savy. Do you know how to solder? This is a 99% fix. Take the back cover off (unplug first). You will see a big heatsink on the board (6-8 inchs long) attached to this are 2 convergence ICs. Unscrew the board, flip it over and resolder all the pins to those 2 chips. Done
Feb 11, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 convergence resistor location and vlaues
5a resistors are all 120 ohm 1/2 watt use flame proof resistors.
check fuse f9a23 or f9a22
also replace knowen bad caps in this unit efecting convergence replace all 10uf @ 16v on the scan doubler module, ther are 8 off them.
make shure and check trace between Rg-8 and r705 for a open, sumtimes fulid from crt will open this up.
regards
daniel.
Jan 13, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Convergence on kdp-65ws550
Good Day, s_d_duncan;
The board for this 2001 Model is no longer available. Now, if you can solder, you can repair yourself. The parts you will need are two STK 392-570 (HIC), convergence IC's, part number 270P150010.
If you can't replace yourself, please call an authorized service center to give an estimate....
Good Luck, big IRISH.
Aug 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46805
Good Day, Bosjerry;
I believe the IC's are on the left of the TV, looking from back, the TV uses STK 392-040 (two) convergence IC's. They will be mounted on a large heat sink (large silver/metal) looking device.
Good Luck, big IRISH>
Aug 01, 2008 | Mitsubishi VS-45607 45" Rear Projection...
MITSUBISHI WT-46805 No Volume
Sounds like audio output IC is bad.Hope this helps. It is on the center circuit board on a little heat sink directly in front of the large Convergence heat sink. It is referred to as IC3E01 and the part number is LA4663. Hope this helps. Let me know if i can assist you further.
Nov 05, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
