Question about Fisher and Paykel Washing Machines
My washing machine is not spinning properly. as it is filling up sometimes it will spin as it use to but then it stops and it will continously beep and 4 lights will stay on on the control panel.
  • Fisher and P... Master
  • 1,525 Answers
Hello billy , spin problems can be caused by the module board this controls the motor speed . but if it's not draining properly this can cause spin problems also some machine have load sensors if you have unbalanced load this can make the machine to not spin properly also sticking brushes on the motor can cause problems test the machine with out any clothes in the are a few possibilitys hope it helps
regards
shaun
Posted on Mar 12, 2011
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France
It could be that the whole machine is out of balance. Here are my (pre-typed!) guidance notes on ensuring it is balanced ;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
My Hoover500MB washing machine sometimes doesnt agitate or spin but will empty and fill
99% of those problems are with the lid switch. Check make sure it is functioning properly.
Oct 03, 2012 | Washing Machines
Machine fills and starts to agitate, then stops. Will pump out & spin but not agitate. Refills with way too much water. Continous 1 second beeps. All lights on or 2nd, 3rd & 4th from left. Not...
Hi just read your posting.Could you please confirm the lights that are on when the machine is beeping as the lights you described that are on is not an error code.Also please confirm the model number for me.It is on s sticker at the back of the machine top left.Looking forward to your reply.
Sep 26, 2010 | Fisher and Paykel Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Fisher & Paykel washing machine. Model MW512NZ. It has stopped working properly. The water is stopping and starting when the machine is filling and although the machine will pump out it will...
Hi just read your posting.Now the lights that are flashing will be in a row of 8 lights.Starting from the left to right which lights are lit,Is it the 2nd and 4th or the 3rd and 6th ---etc---?Please reply with the additional information and I can help you rectify this fault.Looking forward to your reply.
Aug 01, 2010 | Fisher and Paykel Washing Machines
Washing machine wont spin the water out.
IT IS VERY POSSIBLE THAT YOU HAVE A BAD OUT OF BALANCE SWITCH. THE MACHINE WILL NOT GO INTO A HIGH SPEED SPIN IF THE SWITCH IS BAD.
Mar 18, 2009 | Fisher Paykel EcoSmart GWL15
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
