Question about E-Machines eMachines Desktop PC
I have a problem with my computer emachines j4501 desktop pc windows vista home premium..after the windows logo the monitor turn blank...but the cpu is still on.... what will i do...
My desktop computer screen is blank wen restart it goes to the screen tht shows harddrives.. like memory Nero home sum like a control panel I've read every comment on here none matches mines any help fans everything working perfect monitor too
Posted on Jul 05, 2011
  • 442 Answers
If you can see the windows logo screen both your computer and monitor is working, possible problem could be that the display settings are set to high that your monitor is unable to handle it. Restart computer and keep tapping F8 key. This will take you to the advanced options menu In the list of options here choose enable low resolution mode and hit enter (you can only use your keyboard to choose - use the up / down arrow key) once you enter windows low res mode change it to 800 X 600 and restart the computer Once you are in the right mode now change the display settings accordingly.
Posted on Mar 12, 2011
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
How to insert an sd card on a packard bell windows vista home premium computer
Windows logo button ('Start') > Computer > Removable devices.
DOUBLE-click on the file name to the right of - Removable devices
Regards,
joecoolvette
Mar 21, 2013 | Packard Bell Computers & Internet
Monitor goes black
When you shut down your computer is normal. When you turn off your monitor is normal. Otherwise it's possible something not normal happens.
Aug 03, 2012 | Acer eMachines Black EL1850G-42w Desktop...
Worked fine last night, discovered it this morning still turned on but no signal to monitor. Rebooted and it began a consistent beeping with no signal to monitor. Unplugged several times to no avail....
the beeping is coming from the cpu.
1 unplug pc
2 pull out ram chips
3 use an eraser to clean the gold, yes thats gold
what happens is the gold on the ram oxidizes and does not connect properly and can go bad but cleaning it with an eraser sometimes works. take a cpu that is working unplu it pull the ram and you will see the same thing your other pc is doing.
4 reinstall ram (correctly)
5 boot up cpu
6 please vote.
Dec 13, 2010 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
Frecquent shut downs on both computer s with vista home premium
check your ac power voltage input maybe low. chek the cpu fan. scan all your pc virus causing pc to reboot by it self.
Jun 03, 2009 | Dell Inspiron 530 Desktop Computer
My eMachine momitor won't work with another CPU
Run a memtest to see if your ram is faulty. If it is replace and go.
Jan 20, 2009 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
99 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
