Question about Hotpoint Aquarius WMA42 Front Load Washer
MY WASHINE MACHINE DOES NOT SPIN - Hotpoint Aquarius WMA42 Front Load Washer
  • Hotpoint Master
  • 17,129 Answers
If you meant that there is no movement of the motor then the motor must be checked or the capactior to the motor can be weak.
However if the motor does not work only on the spin cycle then the program controller unit is faulty and needs a check or replacement.
Posted on Mar 12, 2011
  • Hotpoint Master
  • 1,525 Answers
Hello. andrew check the pump first it has drain before it spins if the pump is ok then the cause could be the module board this sits at the back of the machine usually has a load of wires coming off it hope it helps
regards
shaun
Wat does blue light flashing under washine machine wen it goes into spin
sounds like its the moter! when it goes in to spin the carbon brushes makes sparks and would prob do this but it normaly does it when the machine has been working a year aprox depending on use! it should not do this if its new or a month old! if under warrenty i would call them to get it checked as sparks is not good!
Feb 28, 2013 | Hoover AAA160 Front Load Washer
Does not spin
If the washer agitates fine but won't spin, then check the lid switch. Most washers will not spin if the lid is open.
Aug 28, 2009 | Admiral Washing Machines
Washine machine won't turn last spin.
If it has a Start-Reset button, try pressing and holding for 3 seconds..
Select a drain and spin prog and try again
Plz rate my suggestion.
Thanks.
Dec 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Machine wont spin
try to check the pumpbelt maybe it is loosen already.. by opening the back cover of the washine machine you can see the motor with pumpbelt attached to it that makes the machine spin..
Sep 22, 2008 | Hoover Washing Machines
Washing machine
Could be one of the springs that hold the drum is broken.
Jun 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Intermitant fault zanussi zwx1506w washine machine
try these two things first:check the brushes on the motor you will have to remove it first they are held on with two screws on each,and also there is a drain filter behind the kick plate at the bottom of the machine if this is blocked it does sometimes cause the machine not to spin properly hope this helps
Mar 06, 2008 | Washing Machines
Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Dec 29, 2007 | Washing Machines
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
23 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
