Question about HP J3680 Officejet All In One Printer
My printer says cartridge error. how do i solve that
  • HP Master
  • 17,129 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Posted on Mar 12, 2011
Printer
The steps below should help you override the error and make the printer accept the cartridges and allow you to print.
Instructions
    • 1
      Remove and replace the print cartridge. If that doesn't solve the error, move on to Step 2.
    • 2
      Remove the print cartridge from the machine.
      • 3
        Wet the end of a cotton swab with rubbing alcohol.
      • 4
        Wipe the copper colored contacts on the print cartridge with the cotton swab to clean.
      • 5
        Wipe the contacts in the printer where the cartridge sits.
      • 6
        Replace the cartridge and try a test print. If removing residue for a clean connection didn't solve the error, move on to step 7.
      • 7
        Turn off the printer.
      • 8
        Unplug the printer from the power source and leave it unplugged for 15 to 30 minutes. This will reset the printer.
      • 9
        Plug the printer back into the power source and turn it on.
      • 10
        Print a test page.
    Regards,
    Suhail
    May 20, 2012 | Lexmark X1240 All-In-One InkJet Printer
    Tip
    How To Remove 077-100 Error in Dell 3130cn Printer?
    This is right that error 077-100 error is belong to Registration and or Exit sensor.
    But if the yellow toner cartridge doesn't run so there will jamming the paper and the printer shows the error (077-100).
    Actually i solve the issue after three days when i guessed and checked the yellow toner cartridge it was tighter than others.
    So i replaced the yellow toner cartridge and solved the issue.
    on Mar 29, 2016 | Dell 3130cn Color Laser Printer
    Error Code E05 Canon MP258
    Error Code E05 Canon MP258 may solve by the following steps.
    1. Press Stop/Reset button for 5 seconds.2. After five seconds release the button.3. Now your printer will start its process and it is ready to use... thanks
    Sep 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Good day! I have a canon pixma mp228 and have "5100" error code. Please help. thanks Francis
    Hello and Welcome to FixYa!
    Error 5100 means that the cartridge can not be detected by the printer
    Actually the printer is not actually loading the cartridge and showing you the error 5100.
    To solve these follow the following steps
    1. Turn off printer
    2. Remove both the cartridges from the printer
    3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
    4. Return the cartridges
    5. Turn on the printer.
    Error will be removed but
    If the problem is not resolved, then best option is to take it back where you purchased it or contact Canon service center about the error code or To get support by Canon on phone, then call at 1-800-OK-CANON (1-800-652-2666)
    They will surely solve it.
    I hope this solution helps you
    THANK YOU and Keep Visiting FixYa
    May 04, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
    5100 error message
    1. Turn off printer
    Error will be removed.
    Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
    Apr 11, 2011 | Canon PIXMA MP540 All-In-One InkJet...
    Service error 5100 on Canon IP 2770
    Hello thanks for using FixYa
    Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
    To solve these follow the following steps. I hope it works
    • Turn off printer
    • Remove both the cartridges from the printer
    • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
    • Return the cartridges
    • Turn on the printer.
    I hope this solution will helpful for you
    Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
    THANKS & Keep Using fixya
    Feb 01, 2011 | Canon Pixma iP2700 InkJet Photo Printer
    I have one printer canon Pixma IP90. Please advise me to solved : "Canon PIXMA iP90 Service error 5100". Thanks so much !
    • Turn off printer
    Jan 29, 2011 | Canon PIXMA iP90 Mobile Printer
    Ink system failure....error code 0xc19a0013....what is this error code and how do i clear it....
    What is HP Printer Error 0xc19a0013 & How to Solve the Error ? 0xc19a0013 ink system failure error shows in the control panel of printer.
    Reason of occurring this error message is listed below:
    • HP printer setup may not be installed properly.
    • Printer cartridges low message.
    • Printer cartridge is damage or not inserted properly.
    How to Solve "0xc19a0013" Error Code for HP Printer
    • Change low or empty cartridges: in case ink alert message is display before this message. Changing the cartridges may solve the issue.
    • Make sure the printer cartridge is installed or inserted correctly
    • Remove the printer cartridge and reinstall that.
    • Use HP Printer Automatic Cleaning Utility to Printheads:In case the error message is occurring ,use automatic cleaning utility of printer for printhead cleanup
    • Update the Printer Drivers :It may happens due to outdated printer drivers. We recommend you this to update your HP printer drivers on regular bases for smooth and flawless printing
    In case your HP printer still display the error message best option is to dial HP Printer technical support Phone number-1-800-436-0509 (US), +44-800-078-6054 (UK), +61-1800-769-903 (AUS)
    1 800 436 0509 HP Printer Technical Support Phone Number
    Jan 04, 2011 | HP Officejet 6500 Wireless All-in-One...
    10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
    Dear Sir,
    I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
    Thanking
    Ajom Khan Hero
    Mobil No.092 5192797.
    Al Nahr Co.Ltd
    Tripoli - Libya
    Jun 17, 2009 | HP Hewlett Packard LaserJet 5200 Printer
    HP J3680 Officejet All In One Printer Logo
    163 people viewed this question
    Seeker5211
    Seeker5211
