Question about Miele Touchtronic G892 Built-in Dishwasher
Miele G892 dishwasher stopped working. No lights at all. There is power from the outlet to the block behind the kick plate. According to manufacturer, there should be lights even with the door open so this likely isn't a door interlock problem. Any suggestions?
  • Miele Master
  • 17,130 Answers
This seems to be a failure of the main program controller unit.It needs to be confirmed that the unit received power, if so the controller is faulty.
Check if there is any fuse , check if there is line break to the unit.
Posted on Mar 12, 2011
Testimonial: "Very logical. Unfortunately, this is likely the costly problem I feared! Thanks Guru."
  • sub2000 Mar 13, 2011
    I checked and there is power to the connector that inputs the controller. The schematic identifies the controller as Novotronic B2 545-A-USA. Is this part reparable and if not, is it only available through Miele?
I have a whirlpool gold series dishwasher. And yesterday it it just stopped working. No lights at all. I went and made sure it is pluggedinto a working outlet. Please help
Need to check voltage at the little junction box behind kick plate being careful not to get shocked.
If you are not able to do this safely have a technician do this and also check your breaker.
Feb 01, 2015 | Whirlpool Dishwashers
Miele intake light on since new sink,disposal installed
check and see if the disposer drain port plug was removed. intake/drain light means slow drain or no drain
Feb 04, 2009 | Miele Touchtronic G892 Built-in Dishwasher
Inlet/drain light has come on on Miele G892 SCU plus dishwasher how do I sort it without an engineer
I haven't worked on your model. However in general you first need to go through the user manual checks to make certain you've not got a silly. Follow their safety instructions. Manuals are available on their websites e.g. http://www.miele.com/manuals/display_manuals.aspx?bhcp=1
Check the drain pump and non return valve are OK and not blocked.
Check the inlet pipe strainer is clear, and if necessary clean it and descale it.
Check you've got water coming out of the outlet on the wall (carefully, its wet - make certain it doesn't go on the electrics)
Test the fixed drain and hose if the machine is empty by putting some water in it and then turning it on - it should drain in my experience.
If all the above is OK, its possible that the machine has leaked into the bottom tray. You'd need to shut off and disconnect the electricity then open up the bottom compartment of the machine - often a plate on the front behind the kickboard trim. If it has got water in, I'd mop it out and then put it back together. i'd then try running the machine. If it worked in that state I'd bother to replace the leaking seals e.g. on a pump shaft.
Good luck with yours.
rupertvdP,
Dec 14, 2008 | Miele 24 in. G892SCU Plus Built-in...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Drain light is on and program stops
clean your waster water output pipe,back side of your dishwasher.
This often gets full of food.
Aug 09, 2008 | Miele Touchtronic G892 Built-in Dishwasher
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwasher ran with wrong soap
add some salt in the cabinet and a bit of water. salt acts as a foam suppressant
Feb 18, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele Touchtronic G892 Built-in Dishwasher Logo
817 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
