Question about Tanita Digital Body Fat Scale with 2 Memory
Changed batteries on tanita scales and display shows 8888 then error and turns off. How do I clear this please ?
  • Lyn Walshe
    Lyn Walshe Apr 06, 2016
    I have had my Tantia machine for nearly three years and could not use as error 8888 kept coming up after a year or so. Read this forum and someone had mentioned they received a new one under warranty.
    So I rang their Cloverdale number and a lady gave me their
    Reply paid number to post back to them in Western Australia. I have just received a brand new scale.
    Thank you Tanita! Only thing is I really have to lose weight Now! Great result.
SOURCE: I have a tanita tbf-612
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
fitnessbalan
  • 59 Answers
SOURCE: I have a Tanita scale. It will not register weight.
Sounds like somehow it was calibrated to your weight as zero instead of 0. I would contact manufacturer here is the contact info.
http://www.tanita.com/en/contact-us/
Posted on Mar 16, 2009
SOURCE: HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Posted on Oct 05, 2009
Testimonial: "The new scale works great and was on sale at Wal-mart for only $29."
SOURCE: When setting Tanita scales specifics, after set, I get an error
I had the same problem with the error message coming up and emailed Tanita. The regional representative contacted me by email. He had me check with new batteries and clean the contacts. Then he cross-referenced my model and lot numbers and said that my scale was still under warranty and if it met the warranty criteria would be replaced. Tanita has a 10 year warranty on this scale and my scale was 5 years old. He gave me an RMA# to submit with my receipt and about 10 days later I had my replacement scale!! Fantastic Customer Service! Thank you Tanita!!!
Posted on Jun 17, 2010
Error code r5 on Tanita BF-350
Just spoke with Tanita Tech support- r5 indicates if the scale is in PC mode (able to receive data from scale). There is a button sequence to toggle between PC mode and stand-alone mode.
1. Press&Hold Zero button, then Press&Hold On/Off.
2. Release.
3. Arrow buttons toggle between PC mode and Stand-Alone, select which mode you would like.
4. Press Set button to select mode.
Hope this helps!
Mar 23, 2012 | Tanita BF 350 Pro Body Composition...
The scale displays 8888 every time you stand on it. If you go to choose p1 it flashes data. Can seem to get the scale to reset using the instructions and removing batteries does nothing
I have a "Thinner" scale. You have to put a little weight on it to activate, it will show 8888. Don't step on, wait a few seconds and it will change to 0000, then step on.
Jan 05, 2011 | Conair WW81 Weight Watchers Body...
Hello, my new device Tanita BC 532 measure weight and body fat%, but no reaction when I try to press rest of the featured keys. I use the description attached, and the weigth and fat% showes alternly on...
My Tanita BC-532 also developed this fault. It seems to be common with a number of the models! I asked Tanita and over a number of emails this is what they said:
"not to place it in wet rooms and remove the batteries if stored for a longer time period."
When I said it was in a bathroom (isn't that where everyone keeps their scales) NOT a wet room - they said any bathroom is classed as a wetroom!
When I said how can you tell if the batteries are just about to run out (that's what seems to trigger the fault) I had no reply; and when I asked how long is a "long period of time" - 2 weeks/ 2 months (we used to use ours every 1-2 weeks) again no reply to this question.
Now out of warranty after 5 years Tanita suggested it I didn't follow either of these instructions above (in the manual, but not defined) then I only have myself to blame. They did suggest one remedy was to:
"1.Take out the batteries.
2.Make a short-circuit between (+) and (-)with a piece of wire.
3.Put the batteries back and try it out.
If that doesn't work, you simply have to discard it. "
Personally I don't think this is satisfactory and I won't buy Tanita again. Scales should last much longer. They should make any warnings clearly defined - especially based on the number of times this happens according to reports from users on internet.
It seems this is a well known fault and I would thus suggest scales are not fit for purpose over longer term. Tanita should own up to this and stop avoiding their responsibilities.
Should you not keep in the bathroom, use every few days, and replace batteries before they get too low - then these scales are great (well they were for the first 5 years!)
Dec 25, 2010 | Tanita BC-533 InnerScan Body Comp Scale
How do you adjust the tanita 1479 scales
what do you mean by adjust it? to calibrate it follow below
Switch off.
2. Press and hold OFF key.
3. Quickly press ON/ZERO key three times then release both keys together. The timing is rather critical, so if it doesn’t work first time, try again.
4. Display shows [ 0.-0- ], followed by [ 0.-1- ].
5. Place 50gm weight on plate.
6. Display shows [ 0.-2- ].
7. Place 100gm on plate.
8. Display reverts to weighing mode.
Mar 12, 2010 | Tanita Health & Beauty
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
Tanita BC-552 Body Composition Monitor Won't Turn On
I contacted Tanita for you and am working on the manual the link here is for the download however the file says it is currupt maybe it will work for you. if not I have requested it from tanita. http://www.tanita.com/en/downloads/personal/
This is the response from Tanita
Thank you for your e-mail.
It appears that this could be a battery connectivity issue.
When you change the batteries – please insure that you are getting a nice tight fit and that the positive side of the batteries are making contact with the inside wire. Sometimes the batteries can differ in length so you can gently pull on the coil to help make it fit more tightly. Also take a look at the inside contact points to make sure there is no rust. If there is rust – you can clean by using a green kitchen scotch-brite pad & a q-tip dipped in rubbing alcohol.
If you continue to have problems we may be able to replace under warranty.
Your scale does carry a 10 year warranty but you will need to have a copy of the original itemized receipt (or order confirmation if purchased online) in order for us to process a warranty claim.
If you happen to have a copy of the original receipt or order confirmation, please contact our customer service line between 8:30 – 5:30, Monday – Friday, (Central Time) at 847-640-9241, and we can issue you a Return Merchandise Authorization for product replacement
Sincerely,
Cheryl Morse
get-attachment.aspx?uid=1.23025525&folder=oldmail&partid=4
TANITA CORPORATION
2625 South Clearbrook Drive
Arlington Heights, Illinois 60005
Office: 847 434 3985
Email: cmorse@tanita.com
Apr 26, 2009 | Health & Beauty
The scale only measures in 'stone' weight
I contacted the manufacturer of the porduct here is what they suggested you do
Please insure that there is nothing inside that area that may be hindering the switch to change from mode to mode.
You can also remove the batteries for a period of 24 hours to see if that will trigger a reset in the unit.
If you happen to have a copy of the original receipt or order confirmation, please contact our customer service line between 8:30 – 5:30, Monday – Friday, (Central Time) at 847-640-9241, and we can issue you a Return Merchandise Authorization for product replacement.
Sincerely,
Cheryl Morse
get-attachment.aspx?uid=1.22887842&folder=oldmail&partid=4
TANITA CORPORATION
Apr 09, 2009 | Tanita BF681 Scale Plus Body Fat Monitor
Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Apr 08, 2009 | Health & Beauty
Mar 26, 2009 | Tanita BC550 Innerscan Body Composition...
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Tanita Digital Body Fat Scale with 2 Memory Logo
582 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
