Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Matching c b antenna with c b radio
I have been trying to match my new cb radio with an antenna that is only 24 to 25 inches tall it is a magnet mount mounted in the middle of the roof of my 1998 toyota king cab pick up. The radio is with a built in SWR meter. The problem is I have tried many times to match it according to the manufactures instructions but I have had no luck. I have tried to transmit after matching it . With no come back I hope I haven't damaged the radio. Oh yes the antenna has a center load. RG58 U is the type of cable I'm using.
Respectfully
Ed Courtright
  • riverrat047 Aug 06, 2008
    To all C B'rs
    Especially those just starting out or over like me. I had a problem when I started out with a c b radio that not only had the regular 40 channels but also had 7 weather channels as well. I was trying to run 2 bands on a one band antenna. To use both you have to use a two band antenna. And if your radio has a built in SWR meter do not use it you have to have an external SWR meter between the receiver and the antenna. That was my other problem I was using the built in SWR meter when I should have used an external one. I hope this is of some help.
    Reguards
    Ed
  • Dean Pitts
    Dean Pitts May 11, 2010
    When you are trying to set your SWR's, are you using an inline SWR meter, or are you assuming you are setting the SWR with the radio's meter and the SWR knob on the radio?
    You can only set the SWR with an external meter and moving the stinger up and down on the antenna. The only thing that the SWR CAL on the radio is for is setting the meter to what the actual antenna SWRs are, which is used the same as a dummy light on a car.
    Dean
    Problem Solver:
  • 5 Answers
Here is some information that will help you test SWR with an inline watt meter. To get proper results you need to use an inline watt meter. Here is a really good site you can go to for help www.cbradiotalk.com
Equipment needed: SWR meter, short jumper coax 3 foot.
matching c b antenna with c b radio - midland.jpgProcedure: The SWR meter needs to be placed in line between the antenna and the CB. Connect the antenna (normally connected to the back of the CB ) to the connector marked "Antenna" or "Ant" on your SWR Meter. Connect one end of the short jumper coax to the "transmit" or "Xmit" on the SWR meter. Connect the other end of your jumper coax to the CB.
Assuming you have a standard SWR meter the switches should read as follows: REF or SWR, FWD, and there should be a slide switch marked "set" or "Adjust". If different consult your meter's owners manual.
With the radio on the lowest channel (1 on CB) and the SWR meters switch in the Forward (FWD) position, depress the transmit switch (key up) located on the microphone. While holding the unit in this transmit mode, adjust the meter needle to the set position using the Set or Adjust knob on the meter. As soon as the needle is in alignment with the corresponding mark on the meter face, flip the switch to the Reference (REF) position. The meter is now showing your SWR on channel one. Note the value and quickly release the microphone switch. Record this reading.
Repeat the previous step on channels 19 and 40.
How to read your results: If SWR on channels 1, 19 & 40 is below 2.0, your radio can be operated safely.
If SWR on all channels is above 2.0 but not in the "red zone" (normally over 3.0), you may be experiencing coaxial cable reaction (bad quality, wrong length, etc.), insufficient ground plane, or have an ungrounded antenna mount.
If SWR is in the "red zone" on all channels, you probably have an electrical short in your coax connectors, or your mounting stud was installed incorrectly and is shorted. Do not operate your radio until the problem is found, serious damage can occur to your radio.
If SWR on the lowest channel is higher than it is on the highest channel, your antenna system appears to be electrically short. Your antenna length may need to be increased.
If the SWR on channel 40 is greater than that on channel 1, your antenna is considered to be "LONG" and reduction of physical height and/or conductor length will correct this situation.
Posted on Aug 15, 2008
What antenna
If you cannot use a magnet mount antenna on the roof then a fiberglass antenna (top loaded) about 4 ft. tall mounted behind the cab on the bed rail.You can usually run the coax thru a rain drain hole in one corner of the bed. The antenna should be tall enough to where the top third of the antenna is above the roof. The taller the ant.is the better the SWR will tune.
Jan 20, 2014 | Uniden PRO520XL 40-Channels Base CB Radio
When i key my connex 3400 hp up the meter drops to 0
If this isn't the result of an incorrectly set switch (ie: the PA / CB switch set to PA, failure to modulate the carrier in SSB mode, set to CW etc.), it is likely to be an antenna / coax connection issue. Double check connectors at the radio and antenna. Remove and inspect for dirt corrosion, etc. Clean up and reconnect. Make sure fittings are at least hand tight. Check for solidly connected antenna mount to the car body. If the type that engages the lip of / or a body panel, make sure it isn't rusty. If a magnetic type, try placing on the center of the roof (if metal & look for evidence of water entry into the base of the mount) Check the entire length of the coaxial cable. Look for places where it may be damaged from pinching between body panels. Crushed, chafed, and cuts in the outer jacket indicate a problem with the way the coax has been routed. Make repairs / replace as needed with thinner diameter coax if needed or reroute away from pinch points. Lastly, check and adjust your antenna for minimum SWR with a meter. A match of 2.0:1 will be required to prevent damage to the radio while transmitting. A 1.1:1 match is ideal, but under most circumstances. a 1.5:1 to a 1.8:1 match is attainable with a little bit of effort.
I hope this helps & good luck!
Jan 20, 2013 | Connex Multicolored Lights 3400 Hp 3400hp...
I have a magnet mount antenna I can't get my swr below 3. company vehicle can't hard mount or drill.
buy yourself an astatic PDC-5 antenna matcher and use it to get your match to a 1.5:1 but before you do that is your antenna one that can be tuned by sliding it up or down if so and you can't get it any lower than 3 then get the PDC5 only about 24.00 plus S&H
Oct 08, 2012 | Connex 3300, Deluxe Amateur Transceiver,...
When i que my mic the display light shows no antenna light unless im touching the antenna i tried this on 2 different trucks
The mounting and adjusting of the antenna is crucial,if it is a magnet mount,the surface must be clean,dry and best to not have any rust,also bottom of the magnet needs to be clean and mount it to the largest area of metal on the vehicle...the trunk lid,middle of your roof are the best.Permanent mounts need to be touching bare metal at the mounting hole not paint,again either mount requires SWR adjustments to match the radio it's attached to,it may require trimming of the metal"whip" if it needs to be lowered for the best reading,also don't rule out the radio chassis might need to be grounded as well.For general safety I would not recommend touching an antenna while it is transmitting any radio signal...if all above is good,you transmit and receive fine,more likely light is faulty or needs it's sensitivity adjusted...Good luck,hope this info helps.
Sep 03, 2011 | Cobra 29 LTD CB Radio
I have a Midland 1001Z 40-Channels Base CB Radio and a Magnetic-mount CB antenna. 29" stainless steel whip and 6" spring. About 46" high overall. All bought from /www.thesource.ca in Alberta...
Try Grounding it better. Its supposed to equal 8.5 ft.(102 inches) but the coil may make that in all.You can clip like 1/8 inch off at time until it goes 2.1 Swr. Thats a good standard. 1.5 SWR is desired. If it don't have a coil with it that may be the problem. You could turn it into a 8.5 ft. antenna by buying a 102" inch whip to screw into the base of your antenna, it depends if it holds or not. You could build you a matcher like this with a solder gun+solder and 2 resistors. Get you a box with 2 female cb antenna inputs. Drill a hole for both Cb antenna inputs into box. Place them into holes screw nuts down snug. Run a copper wire inside to both grounds or a plate somewhat. Run a thick gauge copper wire from center cb ANT INPUT(2) to other input of ANT INPUT(1). Solder 2 100 ohms in parallel from input to Ground. If you could take apart your radio(eliminating the box idea). Just Solder 2 (100 ohm) resistors to your Antenna output then put it back together. 50 OHM MATCH HERE Is the main idea. I've used 75 OHM Tv coax and reduced SWR.
Apr 04, 2011 | Midland 1001Z 40-Channels Base CB Radio
Radio recieving and putting very poor.
Just because its a magnet mount doesn't mean its a 100%. I've sold 4 little wheels made by wilson in the past 2 months and they had a ground problem. If you grab the base of the antenna does it give you more squesh? If so it has a ground problem. Have you had that antenna matched to you truck if not that could be your problem. You need to have your SWR checked on your antenna.
Jul 13, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
I purchased a new 959 and would like to know what the best anteana and coaxe cable for this radio is. I will be using it in my 2007 volvo tractor, I'm a line driver in need of the best use I can get from...
coax---18 ft is recommened, all i sell is double sheilded, but as long as its good coax it should work fine...antenna thats a hard one because you have to match the to your tractor..meaning you have to get it tall enough to get to the top of your tractor...make sure you have a good ground..if you're mounting the mount on top of paint either use self tappin screws or scratch off the paint under the mount. hope this was helpful some things are easier to explain over the phone...if you need anymore help just let me know.
Jan 12, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
CB radio recieves but does not transmit.
I would recommend that you put an swr meter (CLICK HERE) between the radio and the antenna to see if your radio is transmitting anything at all. Also, it will check to see if your radio is correctly matched to your antenna. If your antenna is not matched correctly it will fail to transmit correctly.
Nov 09, 2009 | Radio Communications
Poor receive with my Connex 3300 HP radio
get a K-30 antenna ist magnetic if that dont work your speaker in the Cb is broken
Nov 18, 2008 | Connex 3300 240-Channels Base CB Radio
Matching Antenna, or ??????
If the antenna is tunable, you definitely need to start out by having the swr set properly on the antenna. Also, make sure the plastic ferrel, (the small round white piece) is between the top of the antenna bracked and the antenna itself. It is there to make sure the antenna does not ground out to the vehicle. If the antenna is grounding out, it will be like no antenna at all. I have also had a few customers that have had broken coaxes straight out of the factory package on cheaper antenna setups.
Dean
Rollin CBs
Feb 08, 2007 | Uniden Bearcat Pro PC78LTW 40-Channels...
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
220 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
